Advice on my shopping list
Discussion in '101 Display Basics' started by Lishfish, Dec 27, 2016.
  1. Lishfish
    Lishfish Full Time Elf
    Dec 26, 2016
    137
    13
    Adelaide
    Hi everyone,
    I am new to the computer controlled area of christmas lights and want to do a relatively simple design (maybe ;) )
    Just want some feedback if I could from everyone with my shopping list so far. I want to run some dumb RGB's, some pixels and intelligent lights.
    Controllers:
    1. Dumb controller
    https://www.aliexpress.com/item/30CHANNEL-27CH-EASY-DMX-LED-controller-DMX-decoder-driver-RGB-led-controller/32387978299.html?spm=2114.13010308.0.0.hcD9wo
    2. Pixel Controller (Updated)
    http://www.advateklights.com/shop/pixlite-pixel-mapping/16-pixlite-16-controller.html
    Lights
    1. Intelligent (Updated)
    https://www.aliexpress.com/item/promotion-5m-DC12V-WS2811-150LEDs-10pixes-m-led-digital-strip-waterproof-in-silicon-tube-IP66-WHITE/32493161338.html?spm=2114.13010308.0.0.jnJWMA
    2. Dumb
    https://www.aliexpress.com/item/Waterproof-LED-Strip-5050-fiexible-light-60Led-m-5m-lot-DC12V-White-Warm-white-Red-Green/32254781077.html?spm=2114.13010308.0.0.Knrwsv
    3. Pixel
    https://www.aliexpress.com/item/DC5V-12mm-WS2811-led-pixel-module-IP68-waterproof-full-color-RGB-string-christmas-LED-light-Addressable/32691569167.html?spm=2114.30010308.3.131.8PuRm7&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10033_10059_10032_10099_10078_10079_10077_427_426_10103_10073_10102_10096_10052_10050_10106_10051-10050,searchweb201603_3,afswitch_5_afChannel&btsid=26fd461e-b421-4dfb-8a70-4f48d08c6db0
    I should mention that I will be using Vixen as the sequencing program as it's free and the AusChristmas PDF recommended it.
    I am trying to keep everything cheap for my first year and then upgrading as the years go along.
    I am yet to find a waterproofing box for all the stuff, so any advice there would be awesome!
    Thanks in advance for any help! :D
  2. fasteddy
    Apr 26, 2010
    6,554
    37
    Welcome to ACL, your choices don't look too bad but just wondering if you want to run both 5vdc and 12vdc intelligent lights as you have chosen a 12vdc strip (1) and a 5vdc string (3). This is not an issue as the advatek controller can be divided to use 2 different voltages but will require different rated power supplies thus adding costs
  3. OzAz
    OzAz Full Time Elf Generous Elf
    Dec 29, 2015
    410
    83
    Newcastle
  4. pennymoor
    pennymoor New Elf
    Dec 29, 2016
    4
    0
    Mascot, Sydney, Australia
    don't know if you realize that the ws2811 strip lights that you have on your list are 3 led's to one chip
    mic
  5. OP
    OP
    Lishfish
    Dec 26, 2016
    137
    13
    Adelaide
    I have realized this and since decided that I'd want to use the pixels(5vdc) as the mega tree so that'd run off of one controller mostly anyway. But thanks for your reply! :)
  6. OP
    OP
    Lishfish
    Dec 26, 2016
    137
    13
    Adelaide
    Hey thanks for the reply! I have noticed the site you linked doesnt seem to be active at the moment but I will try again later. Thanks also for the cheaper suggestion. :)
  7. OP
    OP
    Lishfish
    Dec 26, 2016
    137
    13
    Adelaide
    Hey there yes I am aware of this and it would run perfectly for what I want to do. Thanks for the reply! :)
  8. heathwithnoteeth
    heathwithnoteeth Senior Elf Generous Elf
    Aug 23, 2015
    525
    49
    sheidow park
    get your enclosure from cookson controls. good quality and close to the CBD near port adelaide.
    they have 20% off list prices for account holders, ask to set one up.
  9. Kitman
    Kitman Full Time Elf
    Oct 25, 2014
    309
    24
    Munno Para
    WHAT!! they never told me that and I have bought 6 enclosures from them for my display, I better have words with them next time I go in. Although the new range that they have are a pretty good price anyway and cable glands from bunnings are cheap enough so all good.
  10. i13
    i13 Senior Elf
    Jul 5, 2013
    795
    16
    These are hit-and-miss. Some people use them but some people can't get them to work including AAH from Hanson Electronics who designs and sells controllers. See his post here https://auschristmaslighting.com/forums/index.php/topic,8580.0.html
    A rock-solid option is the 27 channel controller here https://auschristmaslighting.com/wiki/HD712
    Just be careful with its Cat5 sockets. I've had no problems with them but lithgowlights tells me their contacts are fragile. They can be replaced with a $5 part from Jaycar if this happens. The dip switches for setting the start address can misbehave too but that can also be repaired and it's easy to work around without repairing. There's plenty of forum documentation on this controller including a way to increase the maximum current that it can handle. Despite what the listing says, these can handle up to 35V. Mine have been running at 31V for the last 4 seasons and haven't missed a beat.
    You have some 2 wire light sets and ordinary DC controllers like the 27 and 30 channel ones can only turn on every 2nd light on these. The only controller that'll give you full control of them is this one http://www.hansonelectronics.com.au/product/dmx2-18/
    Another option for ON or OFF control is to use them with relays on the 27 channel controller.
    This will work but IMO it is well worth spending the extra US $30 for the MKII version which supports much larger numbers of pixels per output http://www.advateklights.com/shop/pixlite-pixel-mapping/50-pixlite-16-mkii-control-board.html
    The PixLites also output DMX so they can provide signal for the dumb controllers.
    These are a good choice.
    These will work and they're a bit sturdier than the ones in silicone tubing. The ones in silicone tubing are better in the sun so I'd only suggest the dumb strip you've linked to if it's going in a sheltered location. This is the one in silicone tubing that lasts better in the sun https://www.aliexpress.com/store/product/LED-strip-5050-SMD-12V-flexible-light-30LED-m-5m-150LED-White-White-warm-Blue-Green/701799_2047639598.html?spm=2114.12010608.0.0.vGDbgH
    Remember to specify RGB because single colour strips are sold through the same listing.
    Another thing to note is the number of LEDs per metre. There's no need to get anything with more than 30 LEDs per metre; 30 is still insanely bright. Higher LED counts will increase the price and voltage drop. The one you've linked to seems too cheap so it might be worth checking whether that's the price per metre.
    For the price difference (or lack of it), you may as well stick with pixel strips. They offer the control in 10cm increments and it is easier to power inject pixels.
    These look ok. I haven't heard of anyone ordering them from this supplier though.
    The outer casing will gradually deteriorate in the sun but it doesn't affect the light output. I have benbrown's black ones which seem better in the sun but I don't know if that's solving or just masking this minor problem. It is also very difficult to tell which wire is which on the black ones.
    Excellent choice. The free software options are overtaking the ones that we have to pay for.
    Have you thought about power supplies?
