Anyone know what these connectors are called?
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by Sonny_Jim, Apr 9, 2019.
  1. Sonny_Jim
    Sonny_Jim New Elf
    Mar 5, 2019
    11
    1
    As per title, trying to find out the name of these connectors so I can buy some more (both male and female):
  2. David_AVD
    Jun 12, 2010
    3,978
    272
    I call them "unavailable to buy". :)
    AAH likes this.
  3. ezellner
    ezellner Apprentice Elf Generous Elf
    Feb 12, 2017
    61
    19
    West Bloomfield, Michigan, USA
    These look proprietary to the manufacturer. You might contact them to see if they can be found somewhere else or even from them.
  4. Benslights
    Benslights Dedicated Elf Global Moderator
    May 2, 2010
    2,569
    217
    Elderslie
    if you want to buy them by 1000 you will have no issue
  5. Mark_M
    Mark_M Apprentice Elf
    52
    8
    Auckland, NZ
    I had an old string off icicle lights with that connector. I got an extension lead with those connectors way back. Don't know if you can still get them. Most standard strings now days use reverse polarity switching than having two channels and a common.
  6. videoman3857
    videoman3857 Full Time Elf
    Apr 21, 2016
    400
    103
    Glass House Mountains
    Make up your own lead.
    use that existing end to connect to the power supply.
    Note which wire is 1, 2 and 3
    Cut the wire off a reasonable distance from the plug.
    Purchase 3 pin connector from a vendor like Ray Wu or AHH
    Connect the new male connector end to the lights.
    Connect the female connector to 3 core cable extension.
    Put the old male end on the other end of the 3 core extension.
    Make sure you solder and heat shrink each wire join after you have confirmed the wire / plug connections are correct
  7. AAH
    AAH I love blinky lights :) Community Project Designer
    3,205
    324
    I was going to suggest that same process.
    Another option is to take some good end on pics of both halves of the connectors and see if the google image search can match them.
    https://www.google.com/imghp?hl=EN
    videoman3857 likes this.
