Arduino Coding Help
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by mitlrpro, Oct 14, 2016.
  1. mitlrpro
    mitlrpro New Elf
    Nov 12, 2015
    22
    1
    Gosford
    Hi All,
    Is anyone able to provide some guidance on this...I'm wanting to combine two pieces of code (I don't even know if it's achievable).
    CODE 1: Is a program to run a large LED scrolling message board using strips. That code is here:
    https://github.com/bigjosh/MacroMarquee/tree/master/Arduino/MacroMarquee
    The 2nd code can take the place of the countdown already present in the 1st code (Fireball Roll In)
    CODE 2: Is a countdown timer that is programmed to display on an Arduino LCD. That code is here:
    http://phys-webapps.csuchico.edu/~eayars/code/countdown.pde.html
    I'll be using the Uno and assume I will need the real time clock add on for the unit.
    Can anyone provide assistance?
    Thankyou
  2. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    400
    62
    Kellyville, NSW
    I can do it but it's not a great time of year for aide projects.
  3. livetoride
    livetoride Full Time Elf Generous Elf
    Jan 11, 2012
    193
    16
    Ballarat
    Its all about looping, So your saying when code one ends, You want it to trigger code 2? Is it a countdown to the show starts or something?
    My knowledge is limited but I have a friend thats pretty good with Adrunio I just want to get an idea of whats happening.
    also post up on forum.arduino.cc they will be able to help you out no worries.
  4. cjd
    cjd New Elf
    Nov 17, 2012
    42
    1
    Gosford, Australia
    It is achievable - but not simple.
    Combining the two isn't too hard (put it all in one file, using the loop from the countdown sketch, then replacing the lcd.* calls with ones to SendChar and similar)
    The hard bit is that the countdown sketch relies on some extra includes/libraries which don't work easily in the current arduino IDE.
    It may be easier to start from scratch using the neopixel libraries to handle the matrix and the 'rtc' library to handle connecting to the real time clock addon (depending on which RTC you get)
  5. OP
    OP
    mitlrpro
    mitlrpro New Elf
    Nov 12, 2015
    22
    1
    Gosford
    Thanks for all your replies...I think I've slightly changed the idea now and might keep this project for next years display.
