Thanks Ryan. Have you used the Pixlight ? I'm looking at maybe the mk4 to start with. To understand the programing and systems. Thoughts?There is also Advatek Lights who are based in Melbourne. Prices are higher than they used to be (due to ongoing component shortages - there's a note on their website about it)
Pixlite is a very easy controller to use, assuming you know either how to manually set up your channels and universes or know how to set it up through Xlights.Thanks Ryan. Have you used the Pixlight ? I'm looking at maybe the mk4 to start with. To understand the programing and systems. Thoughts?
Hi Kate. Any suggestions on a small Controller? Looking at running the E1.31 protocol. Something small to start with and expand fro. Therefor controllers? probably hansons the only one at the moment. pixelcontroller wont have any more falcons until another production run happens
For small then a Rasberry Pi and rPi-28D+ will allow you to get started and get into all sorts of mischief. 2 WS2811 outputs which can each control 800 pixels at 40fps or 1600 pixels at 20fps. There's also a WS2801 output and a DMX output on there that can be played with. The Pi can run your whole show either being just it and a rPi-28D+ or down the track when you suffer even worse from the pixel addiction that you will develop.Hi Kate. Any suggestions on a small Controller? Looking at running the E1.31 protocol. Something small to start with and expand fro. There
Thanks for the info, Sounds like a good solution. How did you drive the dumb LED's. I have heaps of the old dumb led strings, some solar. The solar strings are only 3.6 volts and I'm currently running them off an old car battery with a Buck voltage reducers. Can I use them via a relay or drive them directly from a controller?Yes, PixLite 4 was the first E1.31 controller I used (since 2016). I have a mixture of older style dumb DC LED strings mixed with pixels. This last season all my pixels ran off three different Advatek boards - 2x PixLite 4 MK1 and 1x PixLite 16 MK1. MK1 was the original range (now EOL) with lower maximum pixels supported.
Unlike certain other brands of hardware that can be configured by visiting the controller's IP address in your web browser (e.g. Falcon from Pixel Controller LLC), PixLite configuration must be done using the Advatek Assistant application for Windows/macOS. For some this might (or might not) become annoying particularly if mixing and matching Advatek with other brands.
In order to run dumb led strings, solar etc you'll need to find out weather they're regular DC, or AC that runs them. Easy way to find this out is if only half the lights go when you power them on and if you swap the wires around, the other half light up, if this is the case, they are AC, if they all light up one way and not the other way, they are DC. For running DC lights from a pixel controller you'll want one of these http://www.hansonelectronics.com.au/product/2811dc15/ OR these http://www.hansonelectronics.com.au/product/2811dc30/Thanks for the info, Sounds like a good solution. How did you drive the dumb LED's. I have heaps of the old dumb led strings, some solar. The solar strings are only 3.6 volts and I'm currently running them off an old car battery with a Buck voltage reducers. Can I use them via a relay or drive them directly from a controller?
