ElSalZi
I'm in too I have a mega tree to build.....
How do you proportion the mega tree? is there a formulae? 2.5 x diameter = height or something like that?
This close enough to 1:2 ratio, interesting that that means roughly 70 pixels/5.65m (approx. 12pixel/m @ 3" spacing) - so extrapolating that I'd be looking at 113-115 pixels for a similar height (or 20-21 pixels/ m @ 2")...It really depends on what you use for the base and what pole you have available. I have no idea what my ratio is. I used a 6.5m Gal pole that's inserted into the ground 700mm and then a 10foot trampoline for the base. I did cut off the trampoline legs so it sits 150mm off the ground. That gave me a 70 pixel height with 3 inch spacing using the Boscoyo HD strips.
Do you have a pic of your tree?It really depends on what you use for the base and what pole you have available. I have no idea what my ratio is. I used a 6.5m Gal pole that's inserted into the ground 700mm and then a 10foot trampoline for the base. I did cut off the trampoline legs so it sits 150mm off the ground. That gave me a 70 pixel height with 3 inch spacing using the Boscoyo HD strips.
1 x HD 12mm Megatree Mounting Strip 1000 Feet
or 2 x 500 Ft
