greg58
Hi all, I was looking at some 2811 LED strips on Ali-express, does anyone have any info on this, I have done some searching and haven't found any info on this. It says there are 30 pcs per meter, is this equivelent to 90 leds per meter of the standard rgb strip? Also noted that the life expectancey is 35,000 hrs as opposed to the normal 50,000hrs.
Here is the link below.
http://www.aliexpress.com/item/Dream-magic-color-LED-flexible-RGB-strip-30pcs-SMD5050-and-30-pcs-2811IC-per-meter-casing/915779611.html
