Can I do this? (5x DC barrel plugs on a 3 bank 30A 12V DC PSU)
Discussion in '101 Display Basics' started by Cornelius, May 11, 2019.
  1. Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    Hello all, I'm hoping to confirm that this will work. Photos attached.
    Simply put, I want to connect five 12V devices to the same DC power supply, but it only has 3 banks. Three of the plugs will go to inject power in 5Meters of WS2811, they each draw 6.17A (or 18.5A), the fourth connector will go to a 12V IP camera that draws 1A and the fifth connector will connect to the pixel controller and also power a smaller set of WS2811 LEDS ( around 1.5A). The total load on the 30A PSU would be about 21A, but can I have a device (such as the web camera) that draws 1A connected to the same bank as the 5 meter strip of WS2811 that draws ~6+ amps? Will the PSU just compensate and send out ~7+ or will this get electrically ugly? I don't want to overload the IP camera :).
  2. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
  3. uncledan
    uncledan Full Time Elf Generous Elf
    Dec 27, 2014
    196
    166
    Buellton California
  4. David_AVD
    Jun 12, 2010
    3,986
    275
    As well as the fuse block / board, I'd recommend using something other than barrel connectors for the high current items.
  5. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    Great, thank you. My reasoning for this is to keep everything compact. I could go the blade fuse route for the 1A to the IP camera, but I'm using the Pixlite 4 MKII and it already has four 7.5amp fuses for the LEDs. Does this change the way you'd set it up?
  6. uncledan
    Dec 27, 2014
    196
    166
    Buellton California
    A little more information would be helpful. It sounds to me like you're power injecting everything and not powering pixels with the Pixlite? I don't understand all the barrel connectors.. It sounds to me like you can just power all the pixels with the Pixlite. Many people do exactly what you show in the picture. I just can't recommend it.
  7. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    Thanks for getting back. The three 5M rolls of WS2811 do get power from the pixlite which is mounted next to the DC power supply, but I've been testing the voltage at the end of the 5 Meter strip and it's dropping from 12V to the low ~9V when it displays white. Simply injecting power to the end of the strip solves the problem. I have ordered a fuse box because they will help protect the ends that have injected power. Should I not be getting this much voltage drop off from a standard 5M roll of WS2811? Thanks
  8. uncledan
    Dec 27, 2014
    196
    166
    Buellton California
    Have you tried decreasing the intensity? 100% is too much... Most of us run 40% or less. I don't need to power inject a 5m roll of 30/10 12v strip
  9. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    I could, it is more to have the flexibility to have the intensity at full. I would assume if the intensity is at 60% this would be less of an issue.
  10. uncledan
    Dec 27, 2014
    196
    166
    Buellton California
    Most of my display I build for 100% intensity but don't run over 40%. Even at 100% intensity I can power 5m of 30/10 strip from one end
  11. David_AVD
    Jun 12, 2010
    3,986
    275
    From those current figures, it sounds like you have 60/20 (60 LEDs, 20 controllable sections per metre) 12V strip. They will require power at both ends.
  12. ezellner
    ezellner Apprentice Elf Generous Elf
    Feb 12, 2017
    63
    20
    West Bloomfield, Michigan, USA
    I don't believe those barrel connectors are rated for as much as 6+ amps.
  13. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    Correct, sorry for not including LED specs. It's 60 pixels per meter in groups of three.
  14. OP
    OP
    Cornelius
    Cornelius New Elf
    May 11, 2019
    8
    0
    I know the first few I ordered were 22AWG and that wasn't going to work, the one's I use now are 18AWG. I pulled this design from when I used multiple power supplies with similar barrel connectors for LED lights. If they can't handle 6 or 7 amps, then it must be bad design.
  15. David_AVD
    Jun 12, 2010
    3,986
    275
    I see commercial products all the time with connectors on them that are not correctly rated.
    Cornelius likes this.
