badger4543
hey guys im having a little drama, everything was running fine then i moved some props and tried to setup my layout and i cant seem to work out this overlapping issue.
in the visualiser tab ive got everything lined up how i want to daisy chain my props and appears to be all correct in there but when i run a sequence the effects are all messed up. when i run the check sequence every single prop has over lapping channels.
ive attached some screen shots so hopefully someone can spot something im missing.
also what does the red dot mean in the controller tab? when i click on the fpp\rpi under the controller tab its got a green dot. i assume red means something wrong and green all good..
