Cheap Voltage Meter
Discussion in 'SmartAlec Lights' started by SmartAlecLights, Jun 5, 2016.
  1. SmartAlecLights
    SmartAlecLights Im a SmartAlec what can i say! Community Project Designer
    May 4, 2010
    1,241
    41
    S.A.
    We all Know about Voltage Drop, But do we always take out the Multi-Meter to check?
    Well with this simple $2.50 part off ebay, you can make your own lead an check.
    • About to power inject
      Check each side of the plug to make sure the Voltages are Correct, (The Easy Way)
    • Easy to make, only 3 parts ,mini voltmeter, Rays Plugs, Solder, Heatshrink (3mm black, 6mm white, 16mm clear)
    • Did'nt blow up when Power was Reversed (In my tests :D )
    • Can use one at power supply end, an another one at the last pixel (See real Voltage drop)
    • Apparently there 3v to 30v range (depending on the colour/model)
    [​IMG]
    [​IMG]
    Red - http://www.ebay.com.au/itm/131000844123?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Green - http://www.ebay.com.au/itm/130981177973?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Blue - http://www.ebay.com.au/itm/141049350659?tfrom=130981177973&tpos=unknow&ttype=price&talgo=origal
    Ive only tryed the Green So far
  2. bjpc2716
    bjpc2716 who dares win
    Jul 11, 2012
    685
    12
    melbourne
    thank alec a great idea for newbies
  3. OP
    OP
    SmartAlecLights
    May 4, 2010
    1,241
    41
    S.A.
    Stuff the newbies..
    Perfect for us forgetful ones..
  4. ShimmerNZ
    ShimmerNZ New Elf
    Feb 2, 2016
    37
    0
    New Zealand
    Love it. Great idea. Immediately went off and built my own. Thanks for sharing.
  5. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    575
    30
    Kadina
    thanks , great idea, have ordered two,
    so i can see start and end votages for the longer runs
    cheers Boof63
  6. OP
    OP
    SmartAlecLights
    May 4, 2010
    1,241
    41
    S.A.
    Ive also been thinking of making another but with rays 3 pin plugs.. (as thats what i use for strips etc)
    so i will be able to check them out for voltage drops as well.. (between strips)
    There defiantly something to have.
  7. Heath-LightsOnTapley
    Heath-LightsOnTapley Senior Elf Generous Elf
    Aug 23, 2015
    608
    73
    sheidow park
    can someone chuck up a simple schematic for this please... me is confusimacated. :D
  8. fasteddy
    Apr 26, 2010
    6,635
    66
    [attachimg=1]
  9. Heath-LightsOnTapley
    Aug 23, 2015
    608
    73
    sheidow park
    Thx Eddy! just what the doctor ordered! muchas gracias
  10. fasteddy
    Apr 26, 2010
    6,635
    66
  11. gerry
    gerry Senior Elf
    Dec 19, 2012
    804
    5
    Surrey Hills,Melbourne
    Thanks Alec - and Eddy
  12. tooms
    tooms Full Time Elf
    Jan 2, 2015
    114
    21
    Kalgoorlie
  13. OP
    OP
    SmartAlecLights
    May 4, 2010
    1,241
    41
    S.A.
    Eddy doing current meters with rays plugs might not be a great idea.
    (but it would be great when designing elements to know there current draw)
    Since Rays plugs have been tested around the 5-6amp range.
    Ps. Thanks for the image it makes things allot clearer
  14. fasteddy
    Apr 26, 2010
    6,635
    66
    Why wouldn't it be a good idea. Using it for getting the true value current for each output will help people plan their loads better. The unit is rated at 10 amps and Rays plugs will do 5 to 6 amps, so for that purpose I think its a cheap and easy way to make a combined portable volt and current meter that just plugs in line for testing purposes.
  15. scamper
    scamper Senior Elf
    Jan 5, 2014
    963
    122
    collie
    I just bought some for this purpose and am looking at putting one on each line that comes out, So with a 30amp power supply, I will have 3 meters, It may seem to be a bit of overkill, but at least when I decide to add an extra element, i can look at which power supply i can run another lead from without having to look back at diagrams and start working out which light goes where etc. And besides, I don't know of too many people that run 30amp cables from their power supplies.
