ChromaTrim and Conduit behind eaves
Discussion in '101 Display Basics' started by BigRedNole, Jan 21, 2019.
  1. BigRedNole
    BigRedNole New Elf
    Dec 6, 2016
    16
    2
    USA
    After looking at different options and not wanting to drill a million holes, I ordered some ChromaTrim to test. I first mounted it to PVC, but I think that will be too flexible. I then tried 1/2" EMT. That is far more sturdy and hides well under my eaves. I am making a huge assumption that the fascia is the same size on the high eaves and peaks. I don't see that as being an issue though. My next concern was how to create a snap in or easy on/off mechanism that would allow a center support if necessary. I found that the ChromaTrim is easy to score with a razor to get a notch out for a snap in solution.
    All I need to do now is come up with an easy snap in for the conduit and the mounting should be simple from there.
  2. ezellner
    ezellner Apprentice Elf Generous Elf
    Feb 12, 2017
    63
    20
    West Bloomfield, Michigan, USA
    BigRedNole likes this.
  3. Kotche
    Kotche New Elf
    Jan 14, 2019
    13
    4
    Cable tie anchors like these may also do the trick for you. Depends on how permanent you want the fittings to be. I've read that some use the anchors and paint them the same colour as their guttering/eaves and keep them there all year round. Fixing them with screws or silicone should do the trick. Or outdoor adhesive tape may a half decent option to temporarily attach them to smooth surfaces like guttering (most outdoor tape can be rubbed off pretty easily, unless fixed to plaster).
  4. Dez
    Dez Fueled by Christmas - Inspired by You! Generous Elf
    Dec 16, 2014
    96
    17
    Toowoomba QLD
  5. Cranzy
    Cranzy New Elf
    Dec 24, 2018
    46
    19
    Perth
    Have you found a solution to your problem?
  6. RevRob
    RevRob New Elf
    Aug 3, 2013
    30
    2
    Oklahoma
    Have you ever had problems with these breaking ? I bought the old kind from Holiday Coro and they worked great I bought about 25 of the clear ones last November and had trouble with them breaking very easy!
  7. ezellner
    Feb 12, 2017
    63
    20
    I have not any breakage issues so far.
  8. RevRob
    RevRob New Elf
    Aug 3, 2013
    30
    2
    Oklahoma
    Ok Thank you! I will be getting more soon. I might have got a bad batch.
  9. drakky
    drakky Full Time Elf
    Dec 2, 2012
    364
    79
    Mischka likes this.
  10. David_AVD
    Jun 12, 2010
    3,986
    275
    I've had those DETA branded conduit clips out in the weather for several years now and no issues.
  11. LightsOn81st
    LightsOn81st Apprentice Elf
    Nov 15, 2016
    64
    7
    Seattle, WA
  12. RevRob
    RevRob New Elf
    Aug 3, 2013
    30
    2
    Oklahoma
  13. LightsOn81st
    Nov 15, 2016
    64
    7
    Seattle, WA
    RevRob likes this.
