mborg10
Michael Borg
For current bulk buy please see this thread.
http://auschristmaslighting.com/forums/index.php?topic=7235.msg64979#msg64979
It's back!! Bulk buy is still on
This thread is to confirm order Qty's, price and payment for the Milky White Acrylic Tube.
I have worked out the price per tube at $20.
If you would like to order any amount I will require payment prior to the end of the bulk buy on the 20/02/2015. I will be ordering 200 tubes as per MOQ. Once order is placed, it will be approx 6-8 weeks before you receive your tubes.
You can pick them up or I can have freight organised at your own cost. I did an estimate at www.smartsend.com.au to brisbane for 10 lengths which was $30 & $45 to Noosa. No guarrantees on this price as it is out of my hands. visit smartsend and put in your details for a more accurate quote.
I will also be making a jig in order to bend my tube into arches and for the locals, I may be able to help you out with yours. Sorry interstate but freight would be a killer for bent tubes.
Bulk buy ends 20/02/2015 all payments to be made prior to this date
Description
$20 per tube (plus 3% PayPal fee as per forum rules - to be confirmed by admin if direct bank deposit is acceptable)
Opaque Acrylic Tube
OD wall thickness Length weight
50MM 2mm 3000mm 1.09kg
Tube is rigid at room temp but softens at 130 degrees. I recommend hot sand for bending. This stops kinking
check out this youtube video demonstrating bending PVC. I have tried this on the acrylic and it also works.
DO NOT HEAT TO TEMP IN VIDEO - sand should be between 130 and 160 degrees
How To Bend
Description
Opaque Acrylic Tube
How To Bend
