Andy Combites
- Jul 25, 2018
So this is an odd request. I'm building sever props for a high school marching band show. Each prop has a few hundred LED pixels. Each prop has it's own power source. Falcon F48 Board and then differential receivers on each prop. We need to be able to setup, perform the show, and teardown in 15 minutes. So when it comes to connecting the differential receivers to the F48, I can either run long, single cables out to each prop, or I could daisy chain them. If I daisy chain, I would have ethernet adapters that just facilitate the chain. One prop plugs into the next, and that plugs into the next, etc. So my question is this, has anyone had any problems with data degradation if you daisy chain smaller sections of Cat5 cable? Longer runs would be simpler, but for speed of setup, daisy chain would be faster setup. Thoughts?
