BradsXmasLights
WiFi Interactive
This may be of interest to people who can get old Dell PowerEdge Server supplies for free/cheap:
http://www.gekkoscience.com/products/D750_supply_breakout_board.html
At $42.50 per board (+ power supply itself) it's not exactly cheap, however it's going to be quite efficient and clean high current 12V power. The weird Dell PSU connector itself is actually about $10 alone too.
Other features:
[SIZE=medium]+ 5V and 3.3V outputs for driving auxiliary controllers.[/SIZE]
[SIZE=medium]+ The current share pin to tie together if you wish to use more than one power supply at a time.[/SIZE]
[SIZE=medium]+ Current sense pin, to measure current consumption.[/SIZE]
[SIZE=medium]+ External fan speed controller.[/SIZE]
[SIZE=medium]+ External on for turning more than one supply on at the flip of a single switch.
+ Power good signal to indicate whether the supply is functioning properly.[/SIZE]
...And yes, these can be joined in parallel together to increase output power. The other cheap option is no fancy management and just solder directly to the PSU's voltage pins.
Other features:
