design files for props?
Katekate
Portland, Vic
I'm plaing with making props from the Acoustic Felt you can buy from bunnings, cut with a laser. Saw this idea on Zuckerbook somewhere and since I have access to a laser...
worked out the cut settings that work yesterday and made this as a proof of concept
Does anyone have any design files they can share? drawing HoHoHo is hard.
  • Like
Reactions: AAH
I've spent a fair bit of time playing with "Lightburn" for use with my laser. If you have access to a laser, this will be your best bet for designing files with a lot of ease, yes i'm sure there's a few people who have files to share, but i've found most of the time to the design is way quicker than waiting for someone to send you a file and it's "not quite right" for what your after and have to modify it anyway to fit the size / scale. (also depends on what your laser bed size is too)
Lightburn is brilliantly easy, with a little play, you could have a HoHoHo design knocked out in under 15mins or less
Attached took me about 6 mins to whip up . Designed with 11mm holes
  • HOHOHO.zip
yes. as evidenced by the fact that I have a working laser, I know how to use lightburn.
doesnt mean im any good at drawing HoHoHo.
  • Funny
Reactions: AAH
Your welcome kate :/
you said you had "access to a laser" not you "own". you may have a friend that has one, not much details to go by.
dont use my file then, as clearly I rudely overstepped.
never said I owned it.
If someone asks for a thing, telling them to just make it is not a valid answer.
