Answered displaying pixel by pixel
Juddge
Glenmore Park - Penrith Area
is there a way to display pixel by pixel on a prop in xlights ?
i want to view whioch light the prop displays when that pixel is activated
im hoping to view from xlights which pixel on a prop goes where based on the wiring diagram
i was hoping to light up each pixel 1-139
each or contuniously 1,2,3,4,5 etc
so i can view on the xlights preview what light is displaying so i can better interpret the wiring diagram
On the xlights layout tab on the model data there is the ability to "output to lights" from there. I haven't got any controllers or props hooked up currently but I suspect that it will highlight the selected pixel. Hopefully that helps.
Use test mode in xLights. You can set it node by node on the model, so click through them until you find your issue. Can either be 1 then 2 then 3, or 1 and 2 and 3 etc.
