Dmx controller from Falcon Player
Discussion in 'DMX, E1.31 & Networking' started by code, Nov 24, 2016.
  1. code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    Hi guys, my pixlite 16 has to go back for some testing and I am wondering if this would be a good replacement for my dmx spotlights.
    https://www.led-supplies.com/led-controllers/dmx-controllers/dmx-controller-6a-x-3-channel-rj45-in-out/
    I assume I just run an Ethernet cable from my router to this and it decodes and outputs to the lights?
    Assuming also it will work with xlights ?
  2. caffeine
    caffeine Full Time Elf
    Nov 25, 2010
    115
    0
    Melbourne (Wantirna)
    That's a DMX board that will take DMX signal in and output to dumb rgb lights by the look.
    What you send out over the network is E1.31 data.
    What sort of lights are you running, and how did you have them connected to the pixlite?
  3. OP
    OP
    code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    https://m.aliexpress.com/item/32249441206.html?trace=wwwdetail2mobilesitedetail&productId=32249441206&productSubject=DC12V-input-10W-RGB-DMX-LED-flood-light-IP66-with-13-5mm-4core-waterproof-pigtails-input&spm=2114.01010208.3.1.JbVW5s&ws_ab_test=searchweb0_0,searchweb201602_3_10056_10065_10068_10055_10054_10069_10059_10073_10017_10071_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_1&btsid=27a04b1b-71ed-4539-bad4-6c402ada145c
    These are my spotlights, used the dmx output on the board but it seems to have developed a fault not related to the dmx part.
    So in theory this board would not run my spots with out a bridge ?
  4. kane
    kane Dedicated Elf
    Dec 23, 2010
    1,033
    9
    Your pixlite is acting as the bridge from e1.31 to DMX.
    So a standalone e1.31 to DMX bridge would make sense. I've only got experience with J1SYS devices - I have a DR4 and a D4 (both 4 outputs, the DR4 being the first version that also supported Renard) He also has a D2 (2 outputs).
    Not sure if Ed from J1SYS is around these days though?
    http://www.joshua1systems.com/products/lighting/index.html
    Haven't seen these ones before - not sure if any good:
    http://www.ebay.com.au/itm/E1-31-sACN-To-4-DMX-Universes-Interface-Bridge-F-MagicQ-Satge-Lighting-Controll-/162178276091?hash=item25c2941afb:g:HF4AAOSwZVlXvFFy
  5. OP
    OP
    code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    The bridge part is expensive, so will prob have to pack them away for this year ☹️
  6. caffeine
    Nov 25, 2010
    115
    0
    You don't NEED a bridge necessarily... depending on how you are controlling your lights. If from a PC you can use a USB dongle, either directly to DMX old style pins or better to ethernet.
    Trouble is I'm having difficulty finding one in the UK when I've searched.
    They look like this: http://www.hansonelectronics.com.au/product/usb-dmx-dongle/
  7. OP
    OP
    code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    It will be running from my fpp player, I'll have a search myself
  8. OP
    OP
    code
    code New Elf
    Sep 22, 2015
    34
    0
    UK
    Thanks for the input guys, I think for the cost I may as well pack them up for the year
  9. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    401
    3
    Chirnside Park, Victoria, AU
    The usb DMX adapters can be used with FPP from my understanding. Just need to set it up as an output in the webportal.
    As they are relatively cheap, could be an option
  10. drm1963
    drm1963 New Elf
    Jan 8, 2016
    13
    0
    Tennessee
