E1.31 Bridge, E682, LOR
Discussion in 'DMX, E1.31 & Networking' started by dfullerptown, Sep 23, 2015.
  1. dfullerptown
    dfullerptown New Elf
    Dec 16, 2012
    11
    1
    Pacifica, Calif
    So we are new to the pixel world and seem to have hit a wall. Hoping someone can help us break through
    We would like to run Sandevice E682 to 16 strings of 50 pixels ws2811 we use LOR now and have tried many different setups with no success.
    We have a E1.31 to DMX bridge as well as the Holidaycoro Actidongle/Entec Pro
    We are able to see both the bridge and E682 through their respective IP address's and can run strings thru them
    We have built DMX channels (watching every video) thru LOR S4
    in network settings set up the E131 bridge and then assigned the controller to universes (think out issue)
    So question do we need the E1.31bridge to controller connection or can we use or ??????????to get the light to run thru LOR
    What we want to do is build a 16 string pixel tree and run it thru LOR unless there is a better way??
    Dennis
    SF CA
  2. AAH
    AAH I love blinky lights :) Community Project Designer
    2,690
    72
    I am hoping that you are plugging the E682 into an ethernet connection an not a dmx output like the e1.31 to dmx or entec pro.
    For initial testing of things I would close down LOR completely (especially control panel) and use da_e131 from http://www.da-share.com/software/da_e131/ to send data at the E682 to run the pixels. Once you have the E682 configured correctly and the pixels doing what they are meant to then go back to LOR.
    In LOR you will need the channel configured as dmx channels and in the network setup the dmx universes configured as E1.31 and pointing to the right IP. If you have channels with no valid target (eg universe 99, channel 86) and nothing assigned for that universe in the network configuration then the sequencer will untick "control lights" every time you attempt to output data to the lights.
  3. OP
    OP
    dfullerptown
    Dec 16, 2012
    11
    1
    Pacifica, Calif
    First thanks for the help
    We have tested both of the E682 boards directly connecting thru the Ethernet and pixels work fine.....
    Jim and Sandevice also pointed us to another program for testing and everything is ok.
    My son and I built some channels in the LOR as dmx channels assigning them universe 1 after watching the video tutorials plugged in three strings to the board.
    Question would be would we not need the bridge or one of the adapters (holiday Coro, E1.31 bridge thru the LOR to run the E682.)
    This might be our issue.
    We have the IP addresses listed in the network setup for them but pixels stay off
    Dennis
  4. AAH
    2,690
    72
    Is the control light thingy staying ticked?
    There is also a verifier thingy built into LOR accessible via the control panel that might be worth running over your sequence.
  5. OP
    OP
    dfullerptown
    Dec 16, 2012
    11
    1
    Pacifica, Calif
    The control lights stay's on and the comm listener is connected.
    We are going to try and redo our test dmx set up in LOR and connect the E682 direct when we get home from work
    Dennis
  6. OP
    OP
    dfullerptown
    Dec 16, 2012
    11
    1
    Pacifica, Calif
    Well it turned out to be the LOR software we had upgraded to S4 while in the process of trying all the
    different fixes. When nothing worked we deleted LOR software from the laptop and then reinstalled everything
    and now everything works.........Not sure this is a good thing its pretty crazy being able to control each pixel. Wondering how we can start changing out all our LED's
    regards
    dennis
  7. Timmy
    Timmy New Elf
    Jan 21, 2012
    8
    0
    dfullerptown, My question is regarding the bridge... Did you have to have the bridge or did it work plugging it directly to the show computer? I also am running LOR and need to know if I need to purchase a bridge or if a direct connection worked.
    Thanks in advance,
    Timmy
  8. Skunberg
    Skunberg Full Time Elf
    Jul 10, 2010
    194
    0
    Eagan
    The bridge is typically used for your ac controllers. It covers the ethernet signal from your PC into a DMX signal.
    Rather than using a serial port.
  9. Timmy
    Timmy New Elf
    Jan 21, 2012
    8
    0
    Thank you. I ran successful test strings last night. I hope to hook up to the pixel tree tonight and test it.
