E682 help
Greg
Corona, CA
Newbie here, I just purchased a e682 and I am confused on how to set it up? I am using it for a 16 strip tree (Like a CR tree) and since the 682 has 16 outputs I want to connect each string to one output to avoid having to do power injection,
It will control 7 universes in Multicast but how do I spread out the 7 universe to the 16 outputs and set up in LOR? I have read the manual and am still confused.
Thanks in advance!
barbotte
pembroke,on
ok i am no expert so bare with me ,,,, first did u open the page of sand device??? http://192.168.1.206/ is the default page when open you can select how many string per port ect ,,, most setting is all done with the sand device page even the testing ,,then u can play with LOR set up ,,, also make sure your controler is hook up to pc ect ,,,but no need LOR to play with it ....
cheer
Crazydave
Step 1 . get the controller setup and running on your Ethernet network. (,do NOT plug the e682 into LOR USB485). It should be plugged into your network router,/switch
Step 2. Configure E682 for unicast , and setup e682 for the universe s
Step 3. Setup LOR network for the e682 ip address and universes uyou assigned
Step 4. Get vegomatic from itsmebob to import the channel configurations for your tree for the sequence editor
Crazydave
You should only need 5 universes. 5*510 = 2550 channels
2550 channels / 3 colors = 850 pixels. You have 12*50= 600 pixels
Crazydave
For each group on e682 you will start the next channel to be +1 of the prevoius ending channel
