Early plans for 2014
Discussion in 'How is your display put together...' started by harrison0550, Dec 29, 2013.
  1. harrison0550
    harrison0550 Full Time Elf
    Dec 16, 2011
    190
    0
    Chattanooga TN
    Sadly I have been searching forums all night and still cannot find everything I want to add for 2014.
    1: dripping meteor tubes.
    2: 2 X Pixel mega trees
    3: 2 X pixel fans
    4: 4 X shooting stars
    5: house matrix eh maybe
    My concern is:
    1: The dripping tubes. Either all I find are junk or way to expensive. That and I cant decide if they need to be RGB or just plain white. opinions needed please.....
    2: Cant decide if these should be ray trees with strip or if I should build them with nodes. Being that these will be very close to the street I think they will be to bright if I use strips. Again opinions needed please.....
    3,4,5 I got a firm grasp on.
    Any suggestions for 1 and 2 though?
    [​IMG]
  2. OP
    OP
    harrison0550
    Dec 16, 2011
    190
    0
    Chattanooga TN
    Ok so I think I have the meteor tunes sorted now from Ray.
    [​IMG]
    [​IMG]
  3. arw01
    arw01 Full Time Elf
    Dec 30, 2013
    384
    1
    Eastern Washington
    What's ray;s part number for those rgb tubes, please? I only find solid color ones.
    Wondering about using some t5 bulb covers to roll your own with flex strips or nodes.
    Alan
  4. Christmas on Clarafield
    Christmas on Clarafield Full Time Elf
    Nov 9, 2011
    385
    0
    Melbourne
    Andy I share your dilemma on the pixel tree and that's why I haven't committed to adding one yet. Here's my thoughts having seen most others build threads and show videos. NB I may make some assumptions here based on my perceived notion of relative cost, ease of construction and time required. Everyone has put a lot of work in to their mega trees a d let me say that I am envious of all of them because you have one and I don't.
    I think it comes down to whether you want a 2D or 3D tree.
    Strip tree:
    Easier to construct, ie zip tie to conduit so potentially quicker and cheaper to build.
    More Weatherproof (separate debate that I think fasteddy has talked about)
    But a 2d tree doesn't really excite.
    Node tree:
    More like a traditional mega tree appearance and hence more appealing to me.
    This may all depend on the best viewing angle for your show. Maybe because I always have the "behind the scenes" view of my show I want a full 360 node tree.
  5. andrewa
    andrewa Full Time Elf Generous Elf
    Dec 22, 2012
    226
    21
    Frankston North, Victoria
  6. OP
    OP
    harrison0550
    Dec 16, 2011
    190
    0
    Chattanooga TN
    Here is my 2014 network plans. I'm using dropbox to update seq files between my main sequencing pc and the netbook with xlights scheduler. I just made the xlights directory on both PC's a folder inside dropbox so any changes inside the house auto update on the netbook. I also installed logmein on to the netbook so I could control/test lights in the yard with my ipad or phone. I tested everything before I took the display down this year and it worked like a dream.
    [​IMG]
  7. Trafficman
    Trafficman Teach Me!!!
    May 4, 2012
    136
    0
    Pensacola, Florida
    What did you work out on the tubes? Nodes for the tree looks great!! I will not change that this year. Ready for me to come to Tenn?
    jeff
  8. ScottyJ
    ScottyJ New Elf
    Nov 19, 2012
    33
    0
    Melbourne, FL
  9. Travis
    Travis New Elf
    Dec 31, 2012
    23
    0
    Scott
    Can you give us more detail about your pixel tree ? Number of nodes pre strings, number of strings. etc.... ?
    Looks awesome
  10. ScottyJ
    ScottyJ New Elf
    Nov 19, 2012
    33
    0
    Melbourne, FL
    Thanks Travis
    The tree is 32 strands of 50 12v 2811 pixels each for a total of 1600 nodes, I used 1/2 PVC cut at 15' long the nodes are spaced 3-3/8in apart,
    drove the whole tree on one Sandevice 6804 injecting power every 100 nodes, Ive attached a few pics of the legs
    Scott
  11. Jodenbach
    Jodenbach New Elf
    Jan 10, 2014
    14
    0
    Sherwood Park, AB
    Scott, Job Well done!! that is some of the best Pixel tree work I've ever seen man! That's what I want mine to do, but man, it's time consuming. What software?
  12. ScottyJ
    ScottyJ New Elf
    Nov 19, 2012
    33
    0
    Melbourne, FL
    Thanks Joden
    First year using Light Show Pro, it definitely made things a lot easier
  13. Jodenbach
    Jodenbach New Elf
    Jan 10, 2014
    14
    0
    Sherwood Park, AB
    You did that in LSP!? was that version 2.8? I haven't even seen some of those effects...
  14. ScottyJ
    ScottyJ New Elf
    Nov 19, 2012
    33
    0
    Melbourne, FL
    Yes I did! Using LSP 2.8, most of the effects are Macros using the image and color slider, I just started creating pictures in Open Office Drawing tool and using the image macro on the tree and other elements in the display
  15. Jodenbach
    Jodenbach New Elf
    Jan 10, 2014
    14
    0
    Sherwood Park, AB
    Wow! well it looks killer. I love the spinning ones, very 3D looking. Would you happen to care to share some images so I can see what exactly i need to do? thanks.
