assilem4791
If I rest, I rust.
I can't get this bloody controller working. I just want to use it to play with lights until my falcon comes. If anyone can help. Here is the error I get when trying to upload the sketch.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Generic ESP8266 Module, 160 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:128KB OTA:~438KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
[SPIFFS] data : C:\Users\Melissa\Downloads\ESPixelStick-master\ESPixelStick-master\ESPixelStick\data
[SPIFFS] size : 128
[SPIFFS] page : 256
[SPIFFS] block : 4096
[SPIFFS] upload : C:\Users\Melissa\AppData\Local\Temp\arduino_build_497713/ESPixelStick.spiffs.bin
[SPIFFS] address : 0B000
[SPIFFS] reset : --before default_reset --after hard_reset
[SPIFFS] port : COM3
[SPIFFS] speed : 115200
[SPIFFS] python : C:\Users\Melissa\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1\python3.exe
[SPIFFS] uploader : C:\Users\Melissa\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.7.4\tools\upload.py
esptool.py v2.8
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____....._____
Traceback (most recent call last):
File "C:\Users\Melissa\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.7.4\tools\upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/Melissa/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/Melissa/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
SPIFFS Upload failed!
[SPIFFS] size : 128
[SPIFFS] page : 256
esptool.py v2.8
Serial port COM3
