I have a micronet SP586A dual speed up
The problem is that when I start it up the subnet mask is 255.255.0.0. as it was once on a larger network a second hand device that I once saved from scrap also the IP address is 169.254.x.x and the actual address assigned to the Raspberry Pi3B keeps changing is there a way to obtain static addressing as I will be also including in the show one or maybe more Arduino Mega 2560s to control old AC incandescent lights with relays or motor driven devices.
My home network is the traditional 192.168.0.x with a subnet 255.255.255.0
Every time I restart the network hub it assigns different addresses so if I set the wanted address for the network hub in Xlights with it remain as that address once loaded.
I am a network novice or a illiterate depends on the skills required.
