F16V2 Mounting Plate - 3D STL file
AussiePhil
Administrator
Canberra, ACT, Australia
With the Falcon F16V2 gaining some users here is the mounting plate for it.
The original design was the same as the other plates with a 2mm base but I changed it in the last few days to have a 3mm thick base due to the larger physical size.
It's optimally printed with 4 base layers, 4 top layers and 35% honeycomb infill and 2 perimeter shells
using 0.2mm layer thickness.
the STL file is attached for anyone wishing to print there own.
The side to side dimension is "tight" so if your printer is known to print slightly small you may need to adjust in your slicer.
Phil
  • f16v2_mountplate.zip
