3.x Fades
damo1271
Adelaide
I assume you are referring to vixen 3?
If so then the pulse effect will provide a fade. Select the intensity curve to set the start and end levels. Reverse the curve to fade up or down as needed.
You can also hold control key and click on the curve to add a new drag point if desired.
Hope this helps.
djgra79
Cranbourne West
Does Pulse only work for RGB? I've got some DC icicles that are not RGB but I cannot get Pulse effect to fade up or down on them. My only options seem to be Set Level (on or off) or Candle Flicker. Surely these can still be faded?
djgra79
Cranbourne West
Never mind, I had Colour Handling setup when I shouldn't have - all fixed!
