Hi,
I just want to clarify what the reverse checkbox does in the setup of the falcon controller (cant remember what page it is on, and I dont have it here to check). My setup is as per the attached pic
The left side arches and the right side arches (data) are fed from a differential receiver and are therefore from 2 different outputs. Because the 'controller' is in the centre the right side arches are 'normal' (data left to right), but the left side is backward.
Can I set it up in xlights as 2 sets of 4 arches ordered from left to right, and for the right side setup in the falcon check the 'reverse' checkbox so the controller reverses the data order and outputs it the correct way around?
I have so far not done this, but I have found it somewhat difficult to do chases and such across the whole lot as 1 big group. I assume the backward nature of the left side arches is the problem here.
Thanks for your replies
Kimbo
Kimbo
