Falcon Player - forcing Composite Video Out
Discussion in 'Incorporating video or projection in your display' started by Richie4540, Aug 17, 2015.
  1. Richie4540
    Richie4540 Full Time Elf
    Jul 30, 2015
    109
    17
    Brisbane
    Hi, i have just started with video and have set up 2 raspberry 2's with Falcon Player , and loaded video, and playlists and scripts to get it all going.
    So I have a switched input that fires off the video playlist which will be used at Halloween to scare people, this all works in glorious harmony via HDMI output - I can restart the Pi and it boots up and alls well and plays each time its triggered.
    However i want to be able to play one of the videos through the composite output (for an older projector) and have been trying to get the player to do this reliably. I have so far only been able to get composite to display by holding the shift key on starup and pressing the 3 button - I have then tried to edit the config.txt file to force it to display in composite and not default to hdmi output, but doing this doesnt want to work - and after rebooting I get no display,
    Has anyone suceeding in doing this with a Pi2?
    regards Richie
  2. dpitts
    dpitts Apprentice Elf
    Aug 18, 2011
    66
    1
    Falcon, CO
    Have you disconnected the HDMI output. The PI I think will send out the HDMI if it detects a device connected to HDMI connector.
  3. OP
    OP
    Richie4540
    Jul 30, 2015
    109
    17
    Brisbane
    Yes each time I have swapped connections and performed a reboot with the composite connection made to the tv or projector with the correct input selected on the TV or projector - I have also checked the cable connections and the cable I have the video is actually coming out of the Red connector, so I am using this connected to the video input on the Tv or projector. I have also removed the hdmi cable from the Pi2
    So its a config setup issue - I am not sure if the FPP when it boots modifies the config file or not???
    Regards Richie
