First controller setup and ready to roll!
slw2206
Got my 1st controller setup with a 600 watt PSU. All 16 ports are wired and sealed along with the 4 expansion CATs 😀
Still have to mount my Pi4 in the box, but keeping it out until I have the FPP configured and running properly.
VLS pixels arrived (well 2k out of the 3k I ordered, the last package is stuck in New Jersey) and I hope by the end of the night I'll have them all tested.
Thought I'd post a few pics of the workspace I've created in the basement.
Must be too early in the morning, the pixels look like xConnect and the controller looks like Ray Wu pigtails. 🙃
Also highly recommend adding 2 external ethernet ports, these would either be 1 for the Pi and one for daisy chaining controllers, or if you leave the Pi out of the box, just direct to the 2 controller ethernet ports.
Congratulations! The first controller box is always exciting as it gets you ready for putting a show together and you get to use it for testing also! Your pictures brought to mind a few questions and then also a couple comments.
Questions!
1. Which controller box is that? It's similar to a Bud Box a lot of us are familiar with but is not. Wondering where you bought it.
2. Did the attachment grid come with the box or is that something you might have 3d printed?
3. Where int he US are you located? I don't want to assume your in PA just because you like Penn State. (I'm partial to Alabama and Ole Miss since I paid tuition to those schools :D )
Comments (?)
1. What gauge is the wire from the power supply to the controller? It's hard to tell in the picture.
2. MerryOnCherry mentioned you might want to add in 3 network ports for the PI and the Controller. I'd suggest just using 2 of the four you already have for that instead of adding more to the box. Unless you know for sure you are going to be using all those expansion ports, they tend to be more effort than they are used for. They do however make quick extra network ports if one goes bad since you can just move the port over if needed.
3. The one thing I did notice was that your pigtails seem to be rather short. While longer pigtails might be unsightly they are a lot easier to work with individually if you have more room at the end when working with them. If you need to swap them out my suggestion would be to use longer pigtails.
4. You might consider sticking the pi into a different case or enclosure. If you need to get to the PI for any reason during bad weather I would not want to be opening my controller box to get to it. I run my show in the Midwest from Halloween until after the new year so I deal with a wide range of good and bad weather.
Now, feel free to ignore everything I said because we all have our own preferences on how we want our controllers built. Your controller is neat, orderly and perfectly functional!
@merryoncherry Keen eye. They're not Ray Wu, but they're definitely not xConnect WHICH IS WHAT I ORDERED FROM AMAZON! Figured that one out shortly after I posted this and went to plug in the first set of lights for testing.
@rgabr0 Also, yes Judge Judy was on in the background. Slow TV day but I always need background noise when working.
Aside from how annoying it is to rewire 48 wires into Phoenix connectors, easy fix. The (hopefully) right connectors are arriving Friday... assuming the Amazon vendor gets it right this time.
@Indigogyre That is 14 gauge running to the board. I have some 10 and 2AWG out in the barn but it was -4 yesterday and we have 2 feet of snow on the ground. 14 will do for now and it's an easy swap out that I can do before Christmas arrives.
As you noted with the pigtails being short, that'll resolve itself on Friday when the replacements (and hopefully correct this time) arrive.
The box is from Amazon and the grid and some metal rails/shelves came with it. I do 3D print a lot of stuff as my son has a 3D printing business with 3 X1 carbons in his farm. I'll actually have this box in a covered area so it'll be very well protected and dry.
Also yes, I'm 15 minutes from the university. 4th generation PSU grad, all engineers and we have lots of farm land surrounding the university. My grandfather was an Ag Eng and used to run their herds back in the 80s and 90s.
Sounds like you're making great progress.
My dad went to Penn State, not sure what the exact degree was but whatever a master's in metallurgy was in the 70s.
Regarding Amazon, they have good enclosures and tools, great deals on cheap network switches and cables, and it is easier to get a Pi from them than drive to Micro Center, but as far as blinky stuff goes I suggest the specialized vendors, doesn't cost more and the products are better / more consistently correct for the hobby. The pixels I got off Amazon died in the first season, the edison string lights weren't waterproof as claimed, a lot of stuff not xConnect, costs more there for PSUs than other vendors, etc.
@merryoncherry I never skimp when it comes to lights! I have over 25,000 dumb LEDs that cover my property every Christmas and they're all (with few exceptions) Wintergreen Lighting. Why? Because in 7 years not a single bulb has failed and even if one does the rest of the strings stay on!
I actually check every string when I pull them out of storage just to see if it'll be the year I finally lose a bulb... hasn't happened yet (which is good because they're sealed and you can't replace them)!
Visionary Light Shows has tons of great reviews and they sell quality LEDs, that's where I got first 3k pixels from. The guys are great there and the co-owner runs a 3d print farm, so we've had a few things to chat about :)
Always good advice though, pay for quality so you only have to pay once.
When I manage clients I always remind them, "We don't have time to do it right the first time, but we always have time to it a second time!"
for the Aliex folks, this is the same box https://www.aliexpress.com/item/1005007203650842.html recognised immediately as I use these a bunch and they are great.
Very similar. The mounting plate in mine is black and the entire thing is a square grid so you can mount anywhere, but aside from that they look identical.
I got the Pi4 on WiFi today, CAT cable running to the F16 and remote access setup. All working good with very little lag :)
New xConnects should arrive tomorrow and I also got a 12V to 5V DC box so I can wire the Pi4 into my 12V PSU and get rid of the additional cord/plug.
Gotta get this stack of 3,000 pixels tested. First coro props should be here next week, and I'll start learning the xLights system + programming.
By the time November gets here I just might be ready with a modest show.
@merryoncherry @rgabr0 @Indigogyre
Gents,
Wondering if you can give a recommendation on something. While I have the time and am still in this box wiring I'm just going to go ahead and get a 2nd 600w PSU. Printing a stacked PSU now since I have the depth to go 2 high in my box.
My game plan was to have one PSU dedicated to the F16 and one that I can run to a distribution block for power injection.
Aside from the F8 Distro block (which I'd need 2 if needing the entire 50 amps of a 600w supply), do you guys have any favorites for fused blocks?
I have been reading up on strategies for power injection and am very aware that I'll need to cut certain runs at the midway point to prevent feedback from 2 PSUs on the same + string. Not a problem, I'll be planning out my runs well in advance of any wires actually getting connected.
Curious what you guys are using and if I should just go with the F8 for ease of use and system integration?
Honestly man Im using the falcon distro blocks with the stuff I got but haven’t run a show fully yet as am pretty new but experienced in the area the others can probably help u better but it’s really personal choice
A lot of people would do what you are saying, and it works well for them, but I don't bother.
I have 700W in all my 16-port controller enclosures (2xLRS-350). This is enough for ~200 12V resistor pixels per port on average, and what I did mostly in ~2022-2024. On the few occasions where I want more power on a string, I just use a controller port for it. All the ports can supply data or power, very flexible since I wing it in the field. (If the 16 ports is not enough, I put a 32-port controller there, split into 2 controllers that are closer to the target pixels, etc.)
As of 2025, for new projects I use pixels that are 3x as efficient. This reduces the need for more PSUs dramatically... 400 pixels/port average is far more than I do.
Also, from the same enclosure, I don't bother to break the positive. With so many pixels and so much wire in between power points, the PSUs don't feed back on each other.
@merryoncherry Interesting. One of the first tests I was going to run was to connect multiple strands and see how far they can go before a power drop might be needed (for obvious reasons, less wire = better).
Everything I read said 150-200 lights, but people were basing that off 100% brightness and all white... that's not real life power consumption.
I will be thrilled if I can get 400 pixels before needing to worry!
Oh, as promised... new pigtails, longer pigtails, most importantly the correct pigtails.6049.jpg
