First Medium Tree installed
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by starzen, Nov 9, 2014.
  1. starzen
    starzen New Elf
    Oct 13, 2012
    44
    0
    Stuart, Florida
    very happy
    finally got my first pixel tree set up and it all seems to work. Don't want to call it a mega tree because it is only about 10 foot tall so it is a medium tree ;-)
    Sadly I don't have a lot of real estate in front of my house so I have to limit things so they fit. Although my neighbors don't mind me taking over their yards as well
    I built mine from info from here and other sites. Made a modified portable hole (just made it a little smaller) and used a 3/4 inch black pipe (heavy sucker).
    3 guy wires just to be on the safe side as it is highly accessible to people and right next to the sidewalk
    used a tree topper with 24 hooks but only filled 16 of them for a 270 degree tree.
    16 string made from black plastic strapping (have a few thousand feet left over ..) with 40 5V pixels each. Power injected between each string at the bottom.
    the bottom is made with electrical conduit. Not quite a circle but good enough ...
    added a star on top with 50 pixels on it as well. Using a J1SYS P2
    had one little hiccup because I marked 2 strings the wrong direction and didn't notice until I was finished so the first string was down instead of up but luckily I could just take that string off and move it to the other end of the tree and just twist the tree a few degrees.
    today I will still need to secretly trim the neighbors tree because it covers the view a little .... no they don't mind
  2. Superman
    Superman I Have C.L.A.P and its very infectious Global Moderator
    May 29, 2010
    1,716
    46
    Ipswich-QLD
    Electrical conduit is terrible stuff to use as the base ring, I know this first hand as well.
    One thing I did was tie 4 locations of the ring to the center pole to Round it up a bit.
    Not perfect but a lot better then the oval I first had. [​IMG]
  3. OP
    OP
    starzen
    starzen New Elf
    Oct 13, 2012
    44
    0
    Stuart, Florida
    the circle isn't too bad. I drew a circle on the garage floor and bent two half circles from conduit. I could have gotten a nice circle if I had spent more time on it but i decided it was 'good enough'.
    thought about using other things but the conduit seemed to be the easiest and it could withstand some force to tension the strings.
    i put hooks into the conduit and connected the strings with small bungees and then used bungee cords to hook the conduit ring to hooks in the ground.
  4. gerry
    gerry Senior Elf
    Dec 19, 2012
    805
    5
    Surrey Hills,Melbourne
    Hi,
    Where did you get the tree topper from ?
  5. OP
    OP
    starzen
    starzen New Elf
    Oct 13, 2012
    44
    0
    Stuart, Florida
  6. gerry
    gerry Senior Elf
    Dec 19, 2012
    805
    5
    Many thanks
