Flat Tree design
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by drakky, Jan 25, 2018.
  1. drakky
    drakky Full Time Elf
    Dec 2, 2012
    339
    69
    Hi guys
    as I don't have much space I'm thinking of doing a Flat mega tree sort of mini version ie in the fact that it will only be about 2.1 metres high , all the threads seem to say base should be half of height , so my question is a 2.1 m high x about 1.1 m wide flat tree pixels spaced at 1" (boscoyo strip) 12 strands of 85 pixels on each , would that look ok to display text and images? or is it just plain too small?
  2. NTKing(Brad)
    NTKing(Brad) Full Time Elf
    Dec 28, 2016
    499
    201
    Albany Creek
    Mine is 3mt high, 16 strands. I went for about a two inch spacing at the bottom, but then I just went by eye to get the spacing. I can measure up overall width if that helps you?
  3. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    looks good , thanks , I'm guessing it will be 800 roughly wide, but that might be a bit of an answer I can go to 16 strands same height but maybe 3" spacing at bottom
    might be better that will only be 8 universes or 1 receiver board
  4. OzAz
    OzAz Senior Elf Generous Elf
    Dec 29, 2015
    605
    198
    Newcastle
    The 1 inch spacing will produce quite good graphics and text, but I'd extend to 16 strands if you can.
    my flat tree is 16 strands of 50 pixels at 2 inch spacing, about 2.4m tall, about 1.5m wide at base.
    see (badly taken) pic
  5. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    yeah I'm thinking 1" spacing down the strands and 3 inch spacing at the bottom between strips 8 universes 1 x 600w 12v supply should power it all
  6. roo
    roo Full Time Elf
    May 9, 2014
    169
    15
    Mirrabooka
  7. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    what i'm interested is the spacing between the strips/strings at the top and the bottom
  8. NTKing(Brad)
    Dec 28, 2016
    499
    201
    Albany Creek
    At the top mine is almost touching, a few mm difference. At the base its around 40 to 45 to 50 mm gap.
    Dont worry too much if the gap at the bottom is out by mm at the bottom. The tree is generally viewed from a fair distance away and is not noticable. Lay your strip down on the cross posts and space them out by measure and eye. Then use a texta and mark where the hole is going to be. Dont rush it - measure twice drill once :)
    UPDATE: for those interested, this is the strip I used https://www.aliexpress.com/store/pr...xels-reverse-protection/701799_926778326.html
    Video of my tree
    View: https://youtu.be/E3P5hSarBEY?t=14m15s
  9. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    thanks Brad , not having done this before i only want to make this thing once hate doing things twice and I don't want a p10 panel or matrix as such so I'm hoping it will look good touching at the top would be 25mm then 50mm at the bottom with 25mm between nodes should be ok I think
    NTKing(Brad) likes this.
  10. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    Hi Oz you're using nodes rather than strip it looks like , how did you secure the strip at top and bottom? and did you line up the strip starting from the top or bottom?
  11. OzAz
    Dec 29, 2015
    605
    198
    Newcastle
    nodes on boscoyo strip. lined up strips at top, strips looped over and then looped onto pipe, screw inserted thru one of the cable tie holes to keep in place
    bottom of strip looped over and held on using short bungee cords with bobble on end, different lengths/adjustments to take into account length changing as went further out
    probably the world's worst set up, but it mostly worked
  12. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    so there's a bit of a curve in the rows not straight across each line of nodes?
  13. OzAz
    Dec 29, 2015
    605
    198
    Newcastle
    yes
    I also interwove some spare bits of boscoyo strip horizontally to try and maintain spacing
  14. OP
    OP
    drakky
    Dec 2, 2012
    339
    69
    i've used turnbuckles at the bottom it stretches the boscoyo strip enough to make them straight , i'm going to zip tie 4mm rod in 2 lines across the front and they should all face forwards and not turn and be pretty much dead straight in line
