FPP PI3 with Vast FM Transmitter URGENT HELP
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by ChristmasInKaralee, Dec 1, 2017.
  1. ChristmasInKaralee
    ChristmasInKaralee Senior Elf
    Feb 15, 2014
    551
    134
    Karalee
    So first full night tonight and I have just discovered that the Pi3 does not work properly with the Vast Transmitter, as in it will randomly produce just noise WTF.
    I am using the FPP Plug in with USB Vast as I have no audio in on the vast. Apparently there is no fix for this that I know of.
    Anyone got any suggestions as this has totally destroyed my show.
    Does anyone know where I can get another FM Transmitter from with audio in within the Brisbane area as I will need it tomorrow.
  2. Kitman
    Kitman Full Time Elf
    Oct 25, 2014
    380
    45
    Munno Para
    You could try jerry rigging a car FM transmitter, you know the old school ones that you needed to use before we had Bluetooth or Aux input in the car so you could play audio through your car stereo.
    they are 12v so a spare 12v power supply hooked up is all you need and they have limited range which is good, but a well place piece of wire might increase the range some what, and with 3.5mm audio input it might just be enough to get you out of trouble.
  3. OP
    OP
    ChristmasInKaralee
    Feb 15, 2014
    551
    134
    Karalee
    Thanks Kitman,
    Superman has come to the rescue and has a couple I can try until I can order one in, so will give that a go tomorrow.
    Thanks Superman (Steve).
  4. jjBrisvegas
    jjBrisvegas New Elf Generous Elf
    Dec 21, 2016
    28
    3
    Gold Coast
    I have an unused CZE-05B also if you have no luck - more than welcome to use it. I live/work Gold Coast north.
  5. OP
    OP
    ChristmasInKaralee
    Feb 15, 2014
    551
    134
    Karalee
    Thanks for the offer. I will see Steve today and try his but will keep you in mind.
    Cheers.
  6. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    581
    31
    Kadina
    run the show from Xl on your computer, plug transmitter into headphone jack and away you go
    Cheers Boof63
    (tried 2 years to get pi to run show this will be third and last year- not looking good at this point either)
  7. OP
    OP
    ChristmasInKaralee
    Feb 15, 2014
    551
    134
    Karalee
    Sorry mate, as a Vixen developer I could never do that. :)
    I have two transmitters from Superman so will test them, hopefully they will work.
    Boof63 and NTKing(Brad) like this.
  8. NTKing(Brad)
    NTKing(Brad) Full Time Elf
    Dec 28, 2016
    473
    187
    Albany Creek
    I hope @Superman plays some hero music when he does the hand over, then flies off :)
    Boof63 likes this.
  9. Superman
    Superman I Have C.L.A.P and its very infectious Global Moderator
    May 29, 2010
    1,706
    39
    Ipswich-QLD
    Wait,Wait,Wait... Your a Vixen user, Bring them back!!!!!!!! ;)
    NTKing(Brad) likes this.
  10. Kitman
    Oct 25, 2014
    380
    45
    Munno Para
    Not a user mate a developer, 1 step more awesome than a Vixen User, not sure how many steps more awesome than an XLights user that is :)
    NTKing(Brad) and Superman like this.
  11. OP
    OP
    ChristmasInKaralee
    Feb 15, 2014
    551
    134
    Karalee
    How about I give one of the two back as the EDM is working great. Thanks again.
  12. Superman
    May 29, 2010
    1,706
    39
    Ipswich-QLD
    The EDM served me well here for many years. looking forward to getting over there soon to check it all out
  13. OP
    OP
    ChristmasInKaralee
    Feb 15, 2014
    551
    134
    Karalee
    Thanks, I am just uploading some videos but it doesn't look that good compared to standing out the front.
