Fused Power Distribution PCB 8-Way
Discussion in 'The Development Lab' started by David_AVD, Jan 17, 2018.
  1. David_AVD
    Jun 12, 2010
    3,635
    118
    Here's the 3D render of the new 8 way power distribution board I'll have available soon. The price is not finalised yet, but should be competitive with other current offerings.
    There are 4 power inputs (screw terminals), each rated for 15 Amps. The separate power inputs allows for different voltages (or power supplies) per output pair. It also means you can use multiple 2.5mm cables from the power supplies instead of one large (and hard to crimp) cable.
    Each output is rated for 7.5A max (medium/standard blade fuse) and has an LED to indicate that power is available for that output.
    Currently I plan to supply it as shown with 8 2-pin connectors plugging into the 2 8-way terminal blocks.
    [​IMG]
    B4IGO, heathwithnoteeth, kevr and 3 others like this.
  2. bluzervic
    bluzervic 65,768 Channels, 185 Universes
    Dec 31, 2011
    528
    18
    Fremont, Calif.
    looks good to me, I know I want some of these. Any pics of the connectors that will be used ?
  3. OP
    OP
    Jun 12, 2010
    3,635
    118
    The two way plug-in connectors are like these:
    [​IMG]
  4. videoman3857
    videoman3857 Full Time Elf
    Apr 21, 2016
    283
    47
    Glass House Mountains
    I am using the 4 way version of these for my proposed Mega pixel tree that is on the books for this year, but mine look smaller as I doubt I could get 2.5 mm cable into the wire receptacle. They are a nice positive fit.
  5. OP
    OP
    Jun 12, 2010
    3,635
    118
    The 2.5mm cable size comment was for the input screw terminals, not the plug-in output connectors.
  6. videoman3857
    Apr 21, 2016
    283
    47
    oopps - so it is.
    My how my brain only takes part of the information in nowadays :cry:
    Comprehension is going out the door
