I am building a mega tree using Ruprects guide so all the specs are pretty much the same, 1344 12v lights, 42 lights per string 32 strings, 8 strings per universe, 4 universes.
I have a block of 4 fuses set up, 1 for each universe, and I am using 18AWG speaker wire. I have done some reading and found that the max amp for the speaker wire is 7amps, trouble is, 7.5amp fuses blow!
Should I try 10 or even 15 amp, and over power wire, or should I move to an 8 block fuse holder?
