Gluing Corflute
HertzSwift
Perth
I recently purchased a large wreath from Extreme Lighting Display, it was slit at the back and folded in half for cheaper shipping, which I knew about. The problem I've run into is trying to glue the slit back together, I used araldite one with a long cure time and I know it has strength, but unfortunately it didn't bond well with the corflute and the joint failed. Could anyone recommended a product that has the strength to maintain the join? The wreath has 198 pixels loaded onto it so it has a bit of weight.
HertzSwift
Perth
Right so you didn't even use glue, this method did cross my mind but I was concerned the the bolt heads would be a bit sightly, but now that I've seen it, it's not actually that bad is it? Thanks for the suggestion.
djgra79
Cranbourne West
When I've built coro props and enclosure covers I've just used a hot glue gun. Silicone I guess would also work.
But for larger/heavier props that I'm mounting on the roof, I've made support frames of C-channel aluminium like what you showed above.
Snowy
Phil
Perth Tas
Just do what Kate did , i didnt even worry about mine when i made the frame its very strong .
