HELP !!!!! FPP not able to see Falcon controller
orchidman33
Hi guys. I need help, yes I am still capable of being helped. This is my second year doing Xmas lights, last year things went great, but this year without changing any of my network settings on the Pi3 B+ and the Falcon F16V3. The FPP is saying `could not reslove host name http://192.168.2.50/ - disabling output'
I am able to log onto the F16 webpage and make adjustments,able to ping the falcon, able to log onto the output of the Pi, I am using unicast as last year.
The ethonet of the Pi address is 192.168.2.100, the falcon has an address of 192.168.2.50. All adresses are static. I am running version 4.1 of FPP
:eek::cry:
What has gone wrong
darylc
404 darylc not found
somewhere in your fpp output configuration you have put http://192.168.2.50/ instead of 192.168.2.50 - it may be in the xlights controller setup tab if you are uploading from xlights to fpp
orchidman33
thank you. I found an instance of that and changed it. The error message has now gone :):)
