Ktag
HELP!
Having so many problems with not only my matrix but other props as well, including my PPD Wreath. Have swapped out more than 30 pixels, with no let up in site. Is it a BAD batch of pixels or is there something sinister underneath!!! I did mention some of this back in an older thread...https://auschristmaslighting.com/threads/intermittent-display-issue-in-matrix.14897/post-128108
At this rate I won't have a Halloween show which would be a nightmare (no pun intended) based on the amount of work I have put in.
- swapped out cables; reviewed all power injection wiring; disconnected power injection; swapped ports; checked voltages (from controller & at prop)(have used 14 guage wiring); added in Null buffers near controller, just in case (note PPD wreath is less than 2 metres from differential receiver); tried different diff receiver, different network cable, different power supply
I think it is the pixels, but when do I stop having to splice in replacement pixels (from the same batch). Is this possible?
All these pixels were bought earlier this year - 5000 x 5v. I haven't had any issues with last year's pixels... both 12v and 5v.
Thoughts on what I could try next... or do I just keep replacing pixels! Note: I've sent an email to Tom Zheng
