Right click on the controller you want to draw the image of. Left click, draw controller images. This will bring up the photo you uploaded. If you want to freehand the drawing, pick C9 Line, as an example, make what you wish and number accordingly.
If you want to use macros on you element you just drew, add a new layer in the sequence editor. Right click the controller you drew the image from, and link channels to that layer. Hope this helps
To erase or clear just use the little delete button and have a click...or if you want to delete everything for that channel just right click the channel and press clear channel image.
