How many pixels for radio station sign?
Discussion in 'RGB Lights - Intelligent Pixels and 3-Channel RGB' started by aplant92, Nov 17, 2017.
  1. aplant92
    aplant92 Full Time Elf
    Nov 24, 2016
    126
    10
    Melbourne
    Sorry if this is the wrong area, couldn't see any other relevant boards in custom creations!
    Roughly how many pixels wide and high are these sorts of signs normally? I've got a fair few pixels left over so thinking I might make one! I have both strips and the individual bulb ones.
    Also, ideas as to what I should mount it on/in and how I should get it to sit in the front yard?
  2. David_AVD
    Jun 12, 2010
    3,922
    241
    My tune-to controller PCB is designed for a regular 16 x 32 pixel P10 panel, but is displays the words one at a time due to the size. It's a simple board that plugs in with no configuration required apart from selecting the frequency and optionally the word colours.
    If you want to go bigger (2x2 panels for example) then a HC-1 board is an option, but you will need to deal with the crappy Chinese software. It's not too onerous though and I have a bit of a guide on da-share.
  3. OP
    OP
    aplant92
    Nov 24, 2016
    126
    10
    Melbourne
    I was thinking of just hooking them all up together and then running them through XLights as a model that displays the station the whole time - is this a bad idea/hard to do?
  4. ryanschristmaslights
    ryanschristmaslights Senior Elf Administrator
    Jun 30, 2010
    662
    198
    Adelaide, Australia
    One idea might be to use pieces from your spare pixel strips shining from behind a sheet of coro, with the non-text areas blacked out? @cdjazman's Merry Christmas sign topic might give you some inspiration.
    Alternatively, LED Panels (P10, etc) are good for this sort of thing. I made a sign out of panels totalling 96*48 pixels, which in addition to the FM frequency also cycles through display dates and times.
  5. OP
    OP
    aplant92
    Nov 24, 2016
    126
    10
    Melbourne
    They're some great suggestions, let me investigate.
    I'd be leaning more toward the LED panel though I think (I've seen enough coroflute to last me a lifetime!)
  6. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    583
    31
    Kadina
    First sign was coro going to 2x1 p10 panels this using info above in video.
    Coro (5mm) made box with folds to create all sides.
    Sign was cut out of front face = "Tune to 99.0 FM" used 20 pixel nodes (3 led per node- rectangle).
    sprayed painted it black then slid another piece of 3mm in between lights and front to diffuse.
    Worked very well and still have it in shed as backup, couple of bricks in bottom to keep it stationary!! when using it.
    Hope this helps
    Cheers Boof63
  7. OP
    OP
    aplant92
    Nov 24, 2016
    126
    10
    Melbourne
    Thanks for the info boot, I'll consider that too!
    @ryanschristmaslights do you have suggestions for where I can buy those panels? Are they waterproof?
  8. ryanschristmaslights
    Jun 30, 2010
    662
    198
    Adelaide, Australia
    My panels are from Linsn LED http://www.linsnled.com/ , they are 1/4 scan, outdoor panels (waterproof from the front, when the included gasket is attached to the rear). They are P8, which are a little bit smaller (with leds closer together) compared to P10 panels. I place the tune-to sign near the kerb so P10 seemed too big (a longer distance required for readability).
    Some different sized LED panels can be seen in this video:
    You'll need a HC-1 panel controller like @David_AVD mentioned in his earlier post to run a sign like mine on its own. If you want to control it in a sequencer like xLights, you'll need something else. Compatibility of certain LED Panels and controllers is something you'll need to consider, too. HC-1 supports lots of panel types, if you're happy with a standalone sign: https://auschristmaslighting.com/wiki/LED-Panel-compatibility
  9. marmalade
    marmalade cats & pixels
    Dec 1, 2015
    240
    62
    newcastle
    i've just finished a sign made from 16 rows of 60 led/m strips. 1 metre wide, took a few days to build a case for it,and running from either a pixelstick or T1000 chinese controller with an sdcard. Even at this resolution it's very readable from the street.
    Boof63 likes this.
  10. OP
    OP
    aplant92
    Nov 24, 2016
    126
    10
    Melbourne
    Hey Marmalade, do you happen to have an pictures?
  11. marmalade
    Dec 1, 2015
    240
    62
    newcastle
    updated.. :)
  12. OP
    OP
    aplant92
    Nov 24, 2016
    126
    10
    Melbourne
    Oh wow that looks great, what did you use for the enclosure?
  13. marmalade
    Dec 1, 2015
    240
    62
    newcastle
    7mm ply from bunnings, glued & screwed. Got the piece of smoked acrylic free from a local plastics place for free but should be able to get a piece for $20 if you look hard enough.
    Leds are just mounted on 3mm mdf painted black, that's all you really need if hanging it in a window.
    Boof63 likes this.
  14. Cologne LED
    Cologne LED Cologne LED
    Jun 29, 2018
    21
    1
    Cologne, Germany
    Oh wow that looks great.
  15. Cologne LED
    Jun 29, 2018
    21
    1
    Cologne, Germany
    LED Panels are good for this sort of thing.
