How much does it cost to run 25,000 lights
Discussion in 'The Family Room' started by 924aussie, Dec 4, 2018.
  1. 924aussie
    924aussie Full Time Elf
    Jan 8, 2011
    184
    3
    Chinchilla
  2. denno020
    denno020 Apprentice Elf
    Nov 22, 2016
    62
    19
    Adelaide
    Thank god for LED's
  3. fasteddy
    Apr 26, 2010
    6,637
    70
    Back in the old incandescent days people used to get the consumer mains power line upgraded from the street and their power boards upgraded to cope with the extra current needed to run a large display using incandescent. Many used to suffer strobing lights in their house as when the lights would come on and off then this would create a voltage dip in the supply that caused your lights to dim. I had this issue originally before I went to LEDs
    LEDs allow us to have massive displays using our existing power systems of our houses
  4. denno020
    Nov 22, 2016
    62
    19
    Adelaide
    I wonder what the comparison would be to using 25,000 pixels.. I guess the obvious answer would be 3 times as much as the LED price?
  5. Boof63
    Boof63 Senior Elf Generous Elf
    Nov 7, 2011
    584
    31
    Kadina
    Running approx 16,000 leds, haven't noticed power bill go up much at all, only on for 2-3 hours and mostly running at 60% power or less and then only half on at any one time (flashing.changing etc) so minimal draw.
    cheers Boof63
  6. Simey
    Simey New Elf
    Aug 18, 2017
    18
    0
    I have a mix of led and pixel around 5-7k roughly and have a kw meter on them.
  7. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    197
    5
    Adelaide
    By my estimates, if you had 25,000 pixels then the cost would be as follows:
    Each pixel draws 60mA when fully on (3 colours = white ie 20mAx3)
    25,000 pixels will draw 1500 amps if all are fully on and white. If they are 5V then this equates to 7.5kW.
    With the current electricity tariffs of around 40cents per kWh this means the price is around $3 per hour to run. (Assume our power supplies are 100% efficient!)
    Now of course an all-white pixel display is pretty boring! Assume a 50% on/off duty cycle (ie only half the pixels are on at any given time) and an average of 1.5 colours when they are on. Then we get:
    $3*50%*(1.5/3) about 75 cents per hour. 3 hours per night x 30 days gives roughly $67 for the season.
    Boof63 and denno020 like this.
