How to configure xlight channels for unused pixels
PumpkinCrazy
Hello from San Francisco, CA.
I am working on my first light display with two props. Prop 1 has cutouts for 130 pixels I but the overall number of pixels is 150 (20 are unused and hanging from the prop). I want to connect prop 2 which has 100 pixels no extra pixels after prop 1.
I have a Falcon Controller F16V3. My question is how do I configure the xlight channels so that the 20 unused pixels are skipped? The problem I am having is that xlight is lighting the 20 extra pixels from prop 1 leaving 20 unlit from prop 2.
Thanks from you help!!
PumpkinCrazy
uncledan
Buellton California
Generally we cut off the unused pixels and solder the female connector back on. Thats a waste of 20 pixels.. As @OzAz mentioned you can create a virtual string and add 20 null pixels on the Falcon
Ltmup
less elegant , down and dirty. create a prop of 20 pixels with no effects and put it between the 2 real ones
PumpkinCrazy
@OzAz @uncledan Thanks for your suggestion. I tried the null string approach and it worked. Here's a screenshot of the result in the controller. I did not have to make any changes to the models in Xlights.
