I mistakenly changed something
glenwaye
I've done an update an I mistakenly changed something.
I have the HE123 mk2 version 2.3 with BBG
FPP is version 9.2-2
I can play/start the show from the computer no worries but when I try to run with out the computer the screen on the board just keeps going back to idle and wont play.
The only other thing I've noticed is I can no longer see the temperature it's just showing 0.0c.
FPP mode: Player
Any clues to what I did/changed?
About Cape/Hat​
Version:2.3
Serial Number:FPP_INTERNAL
Designer:Hanson Electronics
Licensed Outputs:16 ('fp' key)
Output Driver:BBB48String
EEPROM Location:Physical
HE123Mk2 16 pixel output cape, with up to two expansions supporting up to a total of 48 pixel outputs | EEPROM Date: 2022-10-28T09:27:57+11:00
Version Info
FPP Version:9.2-2-g71597563
Platform:BeagleBone Black
FPP OS Build:v2025-09
OS Version:Debian GNU/Linux 12 (bookworm)
Hardware Serial Number:BBG122076961
Kernel Version:6.15.0-fpp14
System Boot Time:2025-10-26 18:02:34
fppd Uptime:20:03
Local Git Version:715975639 ChangeLog
Remote Git Version:715975639
Yes but couldn’t get it to play, last year before making a play list I could select a song from the list and it would play so I could check all was working.
Can you post a screenshot or 2 of the playlist, schedule and any other relevant screens.
I've made a play list and schedule and that is working however when I manual try to play the list or songs it will not do it. I'll attempt to video so I can show
It's hard to make out from the video but that appeared to end on a "no network" error.
Are you connected to a network and it's not reporting correctly?
If you're not connected to a network is the controller trying to send to another controller that's not connected?
I just found this on the multisync screen, how do I remove the one that's not actually there?
to me the one i need to remove is the top one?
I've decided to start fresh and see if I can sort it that way. thanks for the help
