On the one I opened the numbers were scrubbed. I can try one of the others. Maybe someone missed scrubbing the IC in one of the others.I cannot determine precisely but it'll be a bit more involved I'm afraid. From the photos best as I can determine the RGB LEDs are transistor driven via the 8 pin IC. As it appears that the input command sensor goes to that IC, I suspect that IC is a PIC of some sorts. That IC will then be the determining factor on what needs done to drive the LEDs from a RGB pixel controller. Is there a number on the 8 pin IC? Numbers on the transistors, the 3 pin devices located close to the RGB/Black wires routed to the LEDs would be nice too although not necessary.
A little good news, these do look like they could be converted I think. My thought is once the IC is known it may be possible to repurpose. If not, remove it and patch in a WS2811 or similar IC.
V+In the second photo, is the legend under the blue wire V- or V+?
Thanks!! What controller do you use, as these are 24v?if your going to gut them (do what i did to my blown 50w leds floods) https://www.tindie.com/products/robg/pixelflood-20w-rgb-flood-light-ws2811-pixel/
great piece of diy kit
