rvenegas
Hi, just making some tests of my christmas props i just found out something with my WS2811 Flex Strip
http://www.aliexpress.com/store/product/5m-led-digital-strip-DC12V-input-WS2811IC-256-scale-10pcs-IC-and-30pcs-5050-SMD-RGB/701799_568458133.html[/size]
[/size]
[/size]i made some windows and door frames, with doors it took an entire 5m strip, however windows frame took 2 strips.
[/size]With the same power supply, at the end of first strip i connecedt the second trip using the ending connection cable of first strip, then i applied power injecting to 2nd strip. Running some tests the second trip does not work.
[/size]
[/size] I disconnected the second one and made a test directly to controller, works fine, i did connect a new strip to the end of first one and no luck.
[/size]
[/size]At this point i'm starting to think that it is not possible to connect 2 strips despite power injecting the second one, the thing is really concerning me is that in the string package it says "please do not connect 2 strings in a row". i dont know if this warning is for power considerations or this is about the ending cable is not able to pass data .
[/size]
[/size]Cheers,
[/size]
[/size]Ricardo.
[/size]
[/size]
[/size]
[/size]
[/size]
[/size]Cheers,
[/size]
[/size]Ricardo.
[/size]
