Leaping pixel arches
Discussion in 'Leaping Arches, Driveway Arches & RGB Arches' started by damo1271, Nov 4, 2014.
  1. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    197
    5
    Adelaide
    I have finally finished building and assembling the first of 4 leaping pixel arches and since they seem to have worked thought I'd share how they were made.
    I saw the no dig garden edging idea floating around some of the forums, but of course it isn't available here in Australia, so created my own version. Using 25mm plastic right angle from Bunnings (about $5 for 2.4m length) I drilled the 12mm holes for the pixels.
    I made a jig so each hole would have the same spacing. I then made another 'cutting' jig and sliced out the gaps between each hole using a hacksaw. This took about 30 minutes per arch but with the jig its very simple.
    The plastic angle is tek-screwed onto some flat 25mm galv steel to give it some rigidity.
    Using the same 25mm galv steel I made brackets that attach to some 'feet' made of scrap timber. My arches will be 4 units wide, but could be expanded to any number of arches.
    I still need to add some support wires to stop the arches swaying side-side, and probably a couple of guy wires to anchor the arches during strong winds.
    The whole thing is bolted together so it will store flat when not in use. :)
    Now just need to fit some pixels and bolt the other 3 units together...
  2. timm1811
    timm1811 New Elf
    Dec 9, 2012
    14
    0
    Good joob on customosing you own. The stuff is avaliable its called link edge and masters has the stuff
  3. abundy
    abundy New Elf
    Dec 27, 2011
    44
    8
    Hey Damo, which section of bunnings did you get the 25mm plastic right angle.
    I went through the store and couldn't see them, but as i am a guy i only did a guy look.
  4. gerry
    gerry Senior Elf
    Dec 19, 2012
    804
    5
    Surrey Hills,Melbourne
    thanks for the info Damo !
  5. OP
    OP
    damo1271
    Oct 12, 2011
    197
    5
    Adelaide
    The plastic angle is in the building section near the timber and gyprock supplies. In all the stores Ive been in, its normally on a rack and stands vertically.
  6. abundy
    abundy New Elf
    Dec 27, 2011
    44
    8
    Cheers Damo.
