Hey all
After lurking around these forums for well over a year and being less than happy with my static lights display last xmas I've decided that I need to stop reading and start doing. For the past few weeks I've been reading, watching and devouring every bit of information that i can get hold of - whether that's a good thing or a bad thing only time will tell!
The thinking at this stage is to start with a mega tree:
Asking a lot I know, but I am the sort of person who likes to get as much sorted as possible before fully committing
Once I get this 1st part sorted I already have plans to add arches, a matrix and a number of other props (have access to a good supply of 2nd hand corflute advertising boards through work) to the display.
So hit me with as much info as you like - the more the better
Jay
- Still till decide if it will be a flat or 180 degree tree. Leaning towards a flat tree that can have singing faces on it
- Would be creating an extension of between 1400mm and 1500mm on top of an existing 1530mm high colourbond fence post
- Using 2811 bullet nodes with 1 inch spacing at this stage. Viewing distance from the road to the flat tree would be around 13m - slightly less with a 180 degree tree.
- Securing the nodes with 12mm mounting strips
- Looking at between 16 and 20 strings initially.
- Starting out with a 5v setup.
- The attached photo shows where the tree would be situated.
- Would be using a Falcon f16v3 controller (have indicated interest in the mega buy thread)
Jay
