Hi,
I have set up iIght Show Pro with all my controllers and drawn in all the items in the visuliser.
I was about to get started sequencing and then realised that the grids for the timing were quite large. I looked in the sequence setting and low an behold it had the timing intervals a 1 second.
I tried changing this to the 1/10 setting multiple times, however ,my computer just freezes and nothing happens. I then tried making a new sequence using the controllers from the previous setup. I selected the 1/10th timing and it worked. Trouble is when I went back into settings it again said it was set at 1 second.
When I originially set up the sequence I am more then confident I made sure I selected the 1/10 timing interval.
Is this a bug? Is there a solution?
