BundyRoy
- Apr 9, 2014
Have set up all my lights on the ecg p12x and they all work but the matrix (10 x 90 pixels ink1003) seems to flicker. When i put it on full white in da e131 it is very bright but almost like a strobe. Everything else works fine. I've tried changing the speed settings in the controller. Doesn't seem to make much difference. The only thing I can think of that's different between the matrix and the other lights is part on the matrix is powered by one psu and the other part another. If I don't have a good enough ground link between psu's would that cause this issue. Will put a direct link in tomorrow in daylight. Anything else that could be causing it. I don't think its voltage drop as I have power to every strip through 2.5mm cable and this has been fine in the past. This is the first time I've used a ecg p12 though.
