Mega Tree Pixel Strings
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by Stephan, Jul 28, 2017.
  1. Stephan
    Stephan New Elf
    Aug 8, 2016
    28
    1
    Parkes
    Hi All,
    Im building my first Mega Tree and are going to order custom strings from - possibly Ray Wu. Planning for 63 Pixels x 20 strings, 140 degree Tree, 5Volts running at 50% intensity Power Injection at bottom every string with T splitters. Also Im planing on using mainly square nodes but Bullet nodes just for the top 3 pixels so the strips can be a tighter fit on the Topper Ring.
    Does this all sound doable?
    Now the main question, whats better or easier to use, 20 strings (63lights) with pigtails on both ends
    OR 10 strings (126lights) with pigtails both ends?.
    Any help would be great!
    Stephan
  2. Fing
    Fing Full Time Elf
    Dec 31, 2014
    376
    38
    Muswellbrook
    don't over think the square/bullet things, my tree is all square and the top is 32mm apart and looks ok .. consider a bigger topper ring instead...I'd go for 20 strings at 63 and put plugs both ends. Make them all the same, it allows for easy swap out if a pixel dies ( plan a spare string) also consider the cost and time to make custom strings.
    fing
  3. OP
    OP
    Stephan
    Stephan New Elf
    Aug 8, 2016
    28
    1
    Parkes
    Thanks Fing, Im building my own Topper based on the 48 hole steel version from Boscoyo, but a bit smaller, mine will be 11" (28cm) in diameter. Trying to get it as small as possible for the tree look and will be growing the string count in the future.
