Mini Trees
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by tweetygirl22, Mar 9, 2013.
  1. tweetygirl22
    tweetygirl22 New Elf
    Dec 19, 2012
    14
    0
    Hi
    I'm wanting to get made or buy 10 mini trees. I only want the mini tree's to be 2ft or there abouts high. I know i can buy them from wow lighting but am trying to source them if possible from here in Australia if anyone knows of them being sold or made by anyone your information would be greatly appreciated.
    Paul and Dale
  2. DougieB
    DougieB Full Time Elf
    Aug 3, 2011
    277
    0
    Gladstone, Qld
    Contact Damian at Christmas Creations
    Here is a link to his mintrees
  3. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    859
    3
    Karaka, Auckland, NZ
    I made my own mini-trees this year.
    I got spiral tomato obelisks, only $12 each at Bunnings. Then put lights on them.
  4. OP
    OP
    tweetygirl22
    Dec 19, 2012
    14
    0
    Thank You ;)
  5. Mm
    Mm Silent Elf
    Dec 15, 2012
    129
    0
    Hi Paul and Dale,
    I got something from Bunnings. Only $12 each.
    https://www.dropbox.com/s/jptefpni6lpiicd/Photo%2010-01-13%2018%2055%2042%20%28HDR%29.jpg
    https://www.dropbox.com/s/i5swsthxvalz8dk/Photo%2010-01-13%2018%2056%2004%20%28HDR%29.jpg
    https://www.dropbox.com/s/h757iypzrozdhro/Photo%2010-01-13%2018%2055%2010.jpg
    MM
  6. penguineer
    penguineer Full Time Elf
    Feb 18, 2011
    202
    0
    Mount Tamborine, Qld
    If you're only after a 2d effect (as in people aren't going to walk around them) use fencing wire to make up a triangle the size you want with the two ends of the wire hanging down the sides....
    Something like this shape:
    Code:
    The prongs stick into the ground so the tree is self supporting and you just wrap light string around it.
    To make it:
    Code:
    Start with your wire:
    Bend both sides up:
    Then cross the sides over at the top:
    And fold the sides back down(so the top part is double wire):
    The straighten the bits at the bottom:
    Cheers!
