My Controller box Build
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by warsome, Oct 28, 2013.
  1. warsome
    warsome Wires? who needs wires!
    Jul 14, 2013
    35
    0
    Adelaide, South Australia
    Hi all.
    So finally finished my Controll boxes for the year.
    In my primary box I have
    -2 * 12V PSU's
    -240V fan
    -Pi with FPP
    -Small wifi router
    -ECG- p12S
    I used B&R cabinets, as I plan to mount them on the wall in my new house.
    First I added fans, had to cut our the vents for intake and have the fan pushing air out (exaust) I did this from experience that when a fan sucks air in, even with the shield, sometimes it will suck in rain and that's never good.
    [​IMG]
    [​IMG]
    The back plates come out of the box, so its easy to drill in everything with PCB screws.
    [​IMG]
    Then, Drilled in glands on the bottom plate for all my pigtails and services (power, Ethernet ect)
    And box One is complete.
    [​IMG]
  2. OP
    OP
    warsome
    Jul 14, 2013
    35
    0
    In my Second box I have
    -2 * 12V PSU's
    -240V fan
    -ECG- p12S -- [soon to have a P12D to replace the P12X]
    - 27 channel Easy DMX LED controller
    [​IMG]
  3. fasteddy
    fasteddy I have C.L.A.P Global Moderator
    Apr 26, 2010
    6,638
    70
    Now thats building boxes to last, A great job and looks neat, better than what Ive done in the past as for me DIY was about saving money so I could never factor in those great steel boxes for the price. But if i was doing it for someone else then thats the approach I would have taken
  4. Habbosrus
    Habbosrus Back again
    Dec 5, 2012
    757
    17
    Swansea, NSW
    Wow! They look fantastic. Kinda' makes my effort seem very amateurish.
  5. David_AVD
    Jun 12, 2010
    3,978
    272
    It appears that you have the high current DC cables passing through the steel base plate with no bushing or grommet? The cables being only single insulated makes this worse.
    I 'd rather mention it now than wait for heat or abrasion to take it's toll and see you post about the fire in your cabinet. :D
    EDIT: It looks like some of the mains cabling is also passing through the base plate unprotected?
  6. OP
    OP
    warsome
    Jul 14, 2013
    35
    0
    I have grommets to put in :) i was waiting for them to arrive (from ebay)
  7. David_AVD
    Jun 12, 2010
    3,978
    272
    Ah, good man! :)
  8. Habbosrus
    Dec 5, 2012
    757
    17
    Swansea, NSW
    I have been able to work things so I can house my power supplies and controllers inside. Here they are in all their glory. Controller box 1 has doors (taken of at the moment). Controller box 2 saw me steal (see borrow) one of the wife's tupperware type containers as a lid (I just have it sitting over it in photo). It did the trick beautifully. I still don't see what her problem was ::) Women and their tupperware containers :eek:
  9. OP
    OP
    warsome
    Jul 14, 2013
    35
    0
    So finished and in production.
    Box 1: (with P12D)
    [​IMG]
    Box2: (sorry bad pic due to sun)
    [​IMG]
  10. Snicko
    Snicko New Elf
    Dec 29, 2013
    18
    0
    Se Melbourne
    How much were the B&R boxes worth?
    We carry a similar enclosure at work that i may look at doing what you have done here also!
  11. dale82
    dale82 Senior Elf
    Nov 19, 2010
    568
    1
    Kingaroy
    I was going to do one of those b&r boxes but the price was the killer
  12. David_AVD
    Jun 12, 2010
    3,978
    272
    The two meter boxes I bought for my display were about $110 + GST each (on special) from memory.
    What I love about the meter boxes is the non-conductive swing out panel.
  13. Steve22537
    Steve22537 Full Time Elf
    Dec 13, 2010
    258
    8
    Harrisdale, WA
    Noticed you've got a WiFi router and a FM transmitter inside the cabinet, are you planning on mounting external antenna's or leaving the door off. Not sure what other problems you may have with your controllers as the RF is very close to them.
    You may want to increase the size of the incoming air vent (I assume its the hole near the hinge)
    Steve
  14. Snicko
    Snicko New Elf
    Dec 29, 2013
    18
    0
    Se Melbourne
    It is deifnitely worth considering doing - I am a big fan of everything in one place! Its the exact reason i have a 48ru cabinet in the garage, if something goes wrong i go to one place!
  15. ChrisB
    ChrisB New Elf
    Dec 4, 2012
    23
    0
    So I like what you did with your controller's in the metal enclosures. I see the small pigtails coming out through the glands. But I also see you mentioned that this box was going to be mounted inside your home. I'm thinking garage??? Anyways have you tested this? I did something like this this year with the power supplies and 2 p12r controllers and it turned out it didn't work. It turns out my distance to first pixel was way to long. I ended up using pixel extenders which I'm not to fond of either. Please post up how this worked for you. Thanks Chris
