My Dalek mini tree
Discussion in 'Mega, Mini, Spiral & Pixel Trees' started by buzzdude, Apr 30, 2016.
  1. buzzdude
    buzzdude Full Time Elf
    Oct 7, 2013
    145
    3
    Chrinside Park, Vic
    Hi All
    Made a mini tree out of coro, 100 pixels, 10 x 10. Took a couple of weeks, while I worked out and researched the measurements, obtain all the bits and pieces that I need to cut, measure and punch out all the holes.
    The crease that can be seen is from when I walked out of bunnings, a gust of wind folded the coro, and I nearly took out the sausage sizzle ladies. Made it to the car a little red faced :-[ . Next time I went, I parked in the timber yard.
    I'm happy with the look, though it does look rough in places as I used a Stanley knife to make the cuts. I don't think it will be noticeable of a night.
    I was going to put a star on top, but haven't made my mind up yet. Was also thinking of a santa hat...
    [font=verdana, arial, helvetica, sans-serif]I've started cutting out the other 9, and have ordered lights from Ray. I'll post again, when I've finished.[/font]
    [font=verdana, arial, helvetica, sans-serif]https://www.dropbox.com/s/2hjld4vkwh8n191/Mini%20Tree.mp4?dl=0[/font]
    [SIZE=small]Shane[/SIZE]
    pmac likes this.
  2. bjpc2716
    bjpc2716 who dares win
    Jul 11, 2012
    675
    9
    melbourne
    great idea
  3. Roosta
    Roosta Full Time Elf
    Dec 8, 2015
    174
    63
    Looks grea mate.. Well done..
  4. BundyRoy
    BundyRoy Dedicated Elf
    Apr 9, 2014
    1,026
    9
    They look really great dude. Love the merry christmas sign. I see what you mean about them being bright. Felt like I was getting a fake tan just watching it.
  5. OP
    OP
    buzzdude
    Oct 7, 2013
    145
    3
    Chrinside Park, Vic
    Hi All
    Finished all the 10 trees, sorry for the blurred video, the phone just can't keep up with the brightness of the lights.
    https://www.dropbox.com/s/1jxuazs5za7ntft/MOV_0235.mp4?dl=0
    I've added additional power at tree 3 and 6, but will need to re asses this when I put them out, as you can see 2 and 5 are a little dark, when all trees are on.
    Stats
    Height 520mm
    Width Bottom 300mm
    Width Top 80mm
    Lights 10 x 10 rows = 100
    Coro 2.5mm
    Board E682
    http://www.aliexpress.com/store/product/DC12V-input-WS2811-pixel-node-100pcs-a-string-IP68-rated-with-all-black-wires/701799_762876648.html
    I'm happy with the outcome, so now will start the sequencing with xlights.
    Shane
  6. Phrog30
    Phrog30 New Elf
    Jul 10, 2015
    29
    0
    US
    http://www.boscoyostudio.com/products/index.php?main_page=index&cPath=2_5&zenid=2cohub8jqaff1vj915uh3ohci6
    Sent from my SM-G900V using Tapatalk
  7. Heath-LightsOnTapley
    Heath-LightsOnTapley Senior Elf Generous Elf
    Aug 23, 2015
    585
    63
    sheidow park
    Nice Job!
    How did you fold the coro?
    cheers
  8. the grinch
    the grinch I guess I could use a little social interaction
    Jun 23, 2013
    442
    54
    angle vale s.a.
    They look very cool well done great job. please don't show my wife anyone!
  9. Red
    Red Apprentice Elf
    Jan 11, 2016
    62
    1
    Mansfield
    hi buzz, Q if l may, how many channels did u use on all ten trees.
  10. Superman
    Superman I Have C.L.A.P and its very infectious Global Moderator
    May 29, 2010
    1,691
    32
    Ipswich-QLD
    I'm going to say 100 nodes per tree which is 300 channels x 10 trees = 3000 channels
  11. Red
    Red Apprentice Elf
    Jan 11, 2016
    62
    1
    Mansfield
    my bad, l meant how many channels on the controller, opps
  12. OP
    OP
    buzzdude
    Oct 7, 2013
    145
    3
    Chrinside Park, Vic
    Hi heath, I used a sharp Stanley knife to cut only one side of the corro. I was then able to fold it while still having it maintain integrity. Though if I pushed too hard I ended up with a cut. I did go over each cut a couple of times lightly to be safe.
    Superman your correct on the channels
    Rudolph, I used 4 outputs, setting the channels at 300, I may change it 2 outputs at 500 if I need the ports for something else. I have also added power injection at the start of every tree, just incase.
    Shane
    Sent from my SGP511 using Tapatalk
  13. battle79
    battle79 Full Time Elf Generous Elf
    Dec 8, 2012
    399
    3
    Chirnside Park, Victoria, AU
    If you make one more you could spell out exterminate! Lol
    10 of them looks even better than the one at the mini.
    Cheers,
    Rowan
  14. pmac
    pmac New Elf
    Dec 19, 2016
    13
    5
    Mulgrave
    Hi Shane,
    Any tips on dimensions as I would like to make these but I am majorly stuck on dimensions. Any help would be greatly appreciated.
    Cheers,
    Patrick
  15. OP
    OP
    buzzdude
    Oct 7, 2013
    145
    3
    Chrinside Park, Vic
    Hi Patrick
    I used the following calculator to work out my dimensions.
    http://craig-russell.co.uk/demos/cone_calculator/
    I new i wanted them to be about 50cm high, so i played with the calculator to arrive at what i wanted.
    Found it was easier to purchase the following from bunnings so I had my Angles correct,
    https://www.bunnings.com.au/craftright-300mm-digital-angle-finder_p5660390
    I drew the outline on a large piece of paper to ensure the cone actually worked...
    From this and the measurements of the calculator I split the cone in 10 equal sections so I had my areas to cut and drew this onto a piece of coro.
    I cut out the outline, then sliced only halfway through each line of the ten sections (9 actually).
    Once finished I was able to see the cone shape.
    From this, then divided each section (vertically) into sections and marked where the holes would go. Punched these out with a hole punch - I did try and drill them quickly but that turned into a mess and partially melted holes, so I stuck with the hole punch.
    Added one string to 100 lights, and used 5 cable ties to hold it together - equally small holes punched out on both the left and right of the cone.
    Hope that helps,
    Let me know if you need any more details.
    Shane
