My first pixel controller setup
Discussion in 'How is your display put together...' started by Grant Astley, Oct 30, 2017.
  1. Grant Astley
    Grant Astley New Elf
    Oct 11, 2017
    21
    9
    Dubbo NSW
    Hi All
    I thought that I would share my first pixel controller setup. Components are
    Raspberry Pi running FPP (Pi will have a wireless link to the router then use lan to talk to the controller)
    F16v3 pixel controller board
    2 x 60A 5V supplies, way over kill for now I know (decided against 12V, for now anyways)
    A few 240Vac fuses and 5Vdc fuses
    At the moment I am only using 10 of the 16 outputs. Will wire the other 6 up next year as they are fiddly to do.
    Please see pictures bellow.
    20171022_210308.jpg 20171029_073709.jpg 20171029_074349.jpg 20171029_074400.jpg 20171029_074403.jpg
    I plan on using it to control a small mega tree with 10 strings. Then next year to increase the size of the mega tree and add a few other items as well.
    Let me know your thoughts both good and bad :)
    Grant
    Verb75, danv and Homer2014 like this.
  2. OP
    OP
    Grant Astley
    Oct 11, 2017
    21
    9
    Dubbo NSW
    And this is how the leads going to the pixel strings are made
    20171026_200735.jpg 20171026_201521.jpg 20171026_201626.jpg 20171026_201713.jpg
    danv likes this.
  3. Mischka
    Mischka New Elf
    Dec 21, 2014
    6
    1
    Wow that is some very detailed craftsmanship going on there!! Great setup and design!! Looking forward to seeing the final light setup!!
    Boof63 likes this.
  4. danv
    danv Full Time Elf
    Dec 5, 2016
    193
    35
    Rockhampton
    Very neat mate. Good to see fusing etc also.
  5. scamper
    scamper Senior Elf
    Jan 5, 2014
    982
    128
    collie
    Looks great.
    For future expansion remember that each output on a f16 can control 640 pixels. So long as you power inject. that way you can use the controller to run many more props.
  6. OP
    OP
    Grant Astley
    Oct 11, 2017
    21
    9
    Dubbo NSW
    Thank you all.
    I thought that they could have up to 1024 pixels per output? Or is that the max and recommended max is 640?
    I plan on using a differential expansion board and receivers to extend to other elements next year.
    Either way I think that this board should keep me going for a while at least
  7. scamper
    scamper Senior Elf
    Jan 5, 2014
    982
    128
    collie
    Sorry my bad, I was thinking the f16v2.
  8. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    456
    79
    Kellyville, NSW
    Even the v2 will soon be able to do 1024 at 20fps.
